2009 Road King/2016 Streetglide fender
I've scoured the forum and can't seem to find specifics on this. I'm wondering if anyone can help me.
Ive got a 2009 road King and I'm putting a 2016 Streetglide fender on it. The Streetglide tailight bar will be used as well. This is where I'm running into issues.
I have the harness and wire bundle from the road king that runs underneath the fender. In this bundle there are 6 wires:
Black
Purple
Blue
Brown
Red
Orange/White
On the Streetglide tailight there are:
Black x3
Blue x2
Purple x2
So basically I need to know what the 6 wires on the Road King do, so I can connect everything up correctly.
I have the diagram for the 2009 Roadking, but it only labels the wires after the next harness and not the 6 wires in the long 'fender' bundle.
Any help is appreciated.
Black
Purple
Blue
Brown
Red
Orange/White
Black x3
Blue x2
Purple x2
you should get a wiring diagram, and read up posts on the SG fender conversion- on pre-rushmore bikes there is a module in the trilight which controls the rear lighting.
Harley forever used this scheme- I know this to be true for 2013 and earlier models- !
black- ground
Red/yel stripe- brake
blue- run
orange white - fender tip or plate light ( international models, run light)
purp and brown are left and right turn signals respectively
You'll need to figure out the fender wiring, a Rushmore ( canbus) wiring diagram is needed
mike
black- ground
blue- run
mike
Thanks mk!
I have the service manual with the diagram. What I am trying to do is clip the wires prior to the module and just connect the tailight wires to the 6 wires coming from under the seat (part no. 68772-06). I just wanted to clip the wires before the pins and solder everything up.
Maybe that's not possible. Do I need that module to run the lights?
Thanks again.
Thanks again.
get a 2016 diagram- I am pretty sure you need the module...I do not have a 2014+ manual so can;t be of any help
2.) soldered joints do not hold up well on vehicles which vibrate- the wire strands will flex and break right where the tinning ends.
not tomorrow but sometime down the road.
oem's use crimp terminals
I solder for a living.
Mike
Mike
