Tank Emblem Removal on Denim Black Paint
Old 05-09-2016, 03:52 PM
lhgdale's Avatar
lhgdale
lhgdale is offline
Default Tank Emblem Removal on Denim Black Paint
Hello, I removed 1 of the tank emblems on my 15 RGS. I used the heat and fishing line method to get the emblem off. There is still some sticky residue left on the tank. Just curious if I could use anything that would not harm the paint or make it shiny? Also maybe you guys have some tips or tricks? I think it looks much better without the emblems.
Thanks
Old 05-09-2016, 03:55 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Mmmmmm! I have used WD40 and a little patience on my bikes, with a soft cloth. The sticky stuff is slowly softened so it can be removed. I don't however have a denim paint, so it will be interesting to see if there is a better way.
Old 05-09-2016, 04:43 PM
Sam2010's Avatar
Sam2010
Sam2010 is offline
Just rub it off with your fingers. Thats how I did it came right off.
Old 05-09-2016, 04:54 PM
lhgdale's Avatar
lhgdale
lhgdale is offline
I've been trying to do that. I guess I need more heat?
Old 05-09-2016, 05:56 PM
Redbeard719's Avatar
Redbeard719
Redbeard719 is offline
Received 1,220 Likes on 545 Posts
I find that lighter fluid (like for a Zippo) works really well. I've never an issue with it hurting paint either.
On the denim finish, you really don't want to rub the same spot very much, or you'll begin to polish that spot into a higher sheen.
Old 05-09-2016, 06:08 PM
Sam2010's Avatar
Sam2010
Sam2010 is offline
I tried a little heat from a hair dryer. I actually thought it worked better without heat. I did one side with heat, dental floss and WD-40. The other side I did with dental floss and my fingers no heat no WD-40. It turned out it came off really easy that way.
Old 05-09-2016, 06:10 PM
Sam2010's Avatar
Sam2010
Sam2010 is offline
Maybe the clear coat on my tank helps those come off. My bike is charcoal Pearl not the denim.
Whatever you do just be patient, be patient keep working at it. If you try any type of cleaners or products spot check it first.
Old 05-09-2016, 06:12 PM
Sam2010's Avatar
Sam2010
Sam2010 is offline
I apologize in advance for the multiple posts. You can try glass cleaner that might cut the greasy sticky. I don't believe the glass cleaner hurts the paint either that's what my buddy uses on his denim bikes. He has 2 black denim bikes.
Old 05-09-2016, 06:48 PM
JAKE 2544's Avatar
JAKE 2544
JAKE 2544 is offline
Shouldn't need heat to remove the adhesive. Roll a corner up with your thumb then try to grab a corner at a 45 degree angle and slowly pull the tape. If that doesn't work just keep rolling it up with your thumb in the same direction.
Old 05-09-2016, 10:48 PM
Ndfastln's Avatar
Ndfastln
Ndfastln is offline
3M (or similar) Adhesive Remover, will take it off without harming the paint. Also wax and grease removers will do the same.
Quick Reply: Tank Emblem Removal on Denim Black Paint
