Will it work???
so not a bolt on- but the showa forks from 1978 to 2013 went through a number of versions and many of the parts swap easily- you could get lower legs and brake and axle to match the wheel- and you may ( or may not) have to swap internals and the fork tubes...
or buy complete forks and they'll slide right into your triple tree
mike
mike
An additional option would be to use a 2000-07 1" axle and 1" ID x 21mm wide bearing (better designed bearing, imo)
Read here
https://www.hdforums.com/forum/touri...l-install.html
Read here
