Boom Box Navigation Issue
Old 07-24-2016, 03:23 PM
noyb43's Avatar
noyb43
noyb43 is offline
2nd Gear
Angry Boom Box Navigation Issue
2016 Road Glide Ultra - I use an external program to create touring routes. My first time to upload a route to the new Boom Box system went well. But, while following the route I had programmed, the Boom Box programming: FASTEST:SHORTEST:SCENIC:TWISTY took over and modified my intended route, depending on which of the above was selected as a default. Anyone else experience this? Any way to turn the defaults off? Options? The program I've used for years for routing planning is TYRE.
Thanks for any suggestions.
Old 07-24-2016, 06:22 PM
fastglass's Avatar
fastglass
fastglass is offline
I use Tyre also,you need to add more waypoints along your route and it will work just fine.
Old 07-24-2016, 07:04 PM
noyb43's Avatar
noyb43
noyb43 is offline
2nd Gear
Default Tyre
That's unfortunate in some ways. Try to judge time/distance to the next major route turn will become moe difficult. I wonder if others have experienced this with Harley's route planner. It would be great if we could turn off Harley's defaults. Thanks for your reply. I will try that.
Old 07-25-2016, 02:10 AM
valpal's Avatar
valpal
valpal is offline
Dude, read this. Has everything you need to know. All is good. ;-)
Old 07-25-2016, 11:32 AM
noyb43's Avatar
noyb43
noyb43 is offline
2nd Gear
After reading everything, I guess the only real fix is to use more waypoints. When I programmed a route and loaded it to my Garmin, I never had an issue with the Garmin algorithms overriding my planned route. I guess Harley thinks they know better. An archaic fix to a silly problem. Thanks for all the replies. Great forum!
Old 07-25-2016, 11:59 AM
RollaMo's Avatar
RollaMo
RollaMo is offline
Perhaps you just got lucky?
I have a stand alone Garmin and I have experienced the Garmin map algorithms overriding the exact route I had on the computer screen.
ALL GPS units operate the same way when importing a route.
Your actual route isn't really uploaded into the unit.
Only the starting point, ending point, and any way points in between are loaded.
They are just latitude and longitude points on a map.
The GPS unit (any of them), then uses it internal mapping algorithms to guide you on the road between those points.
If there is only one or two ways to get to point B from point A, then they will all pretty much take the same route.
But if there are lots of different ways to get to point B, then various GPS units might calculate that route slightly different.
Old 07-25-2016, 12:27 PM
noyb43's Avatar
noyb43
noyb43 is offline
2nd Gear
I've used the same Garmin since 2009, with lifetime map updates. I've always used Tyre to program my routes, then connect my Garmin to my computer to upload the routes. Never an issue with Garmin overriding my planned route. Just an FYI.
shh2734
Audio Systems
07-08-2019 04:35 AM
SN8KBYT
2014-2023 Touring Models
02-20-2017 03:04 PM
EricP
09-16-2016 12:58 PM
No1tncowboy
05-25-2013 03:24 PM
murph
12-23-2012 05:21 PM
Quick Reply: Boom Box Navigation Issue
