usb port inside roadglide glovebox
Yes. I did.
Pac USB-DMA Dash-Mount Adaptor for USB Accessories
It's tight to get in there if you have the liners in the glove box. I used some engineering to make it hold tight.
The last picture shows the led I mounted to each glovebox door, then wired to the lighter circuit. Helps at night.
Thanks for the pics and info, the one I was looking at was threaded and had spade connectors, figured I could unplug the cig lighter and plug into the sub, it has an in line fuse. Was just wondering how much room between back wall of glove box and outer fairing for clearance.
Thanks
Flash
Thanks
Flash
Thanks
Flash
Thanks
Flash
