Chirping engine noise?
Old 08-08-2016, 02:26 PM
STLBagger's Avatar
STLBagger
STLBagger is offline
Default Chirping engine noise? YouTube link attached
Hey guys
I did some motor work in the winter and installed the s&s 106" kit with s$s oil plate, port polished heads, woods 555 cam's, s&s push rods and lifters. After about 1000 miles i get this weird chirping noise coming from the throttle body area it seems.
It's not constant either. It only makes the noise when the engine is at full running temperature, and will randomly happen while riding. I can be sitting at a stop light with no noise, then all of
a sudden it starts making the noise.
I have no power loss, no oil pressure loss, no oil leaks I see, nor any exhaust leaks I see.
What the hell is this?
https://m.youtube.com/watch?v=B5i5vq_OkmU
Old 08-08-2016, 03:18 PM
Scooterbear's Avatar
Scooterbear
Scooterbear is offline
Are you running an open intake? Is it the intake valves closing that you're hearing?
Had the same issues when I ran an open intake. Put the football cover back on and the sound went away.
Good Luck.
Old 08-08-2016, 03:38 PM
STLBagger's Avatar
STLBagger
Good Luck.
I am running a screamin eagle cone intake. I can try this for sure. Only issue I have is my buddy and I did the same build to both our bikes and he has no sound like this
Old 08-08-2016, 03:39 PM
eichacsj's Avatar
eichacsj
eichacsj is offline
What my AC off I hear churping noise. So agree it may be intake valves.
Old 08-08-2016, 03:43 PM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,628 Likes on 1,176 Posts
It may be pushrods rubbing against the tubes. The pushrods rotate as the engine runs, if they are real close to the tubes, and slightly out of round it can cause this noise. The cure is to drill out the pushrod tubes.... 5/8" I think.
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 08-08-2016, 03:45 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Could be a leaking MLS head gasket.
Old 08-08-2016, 03:46 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,524 Likes on 1,421 Posts
All heat shields tight?
Old 08-08-2016, 03:48 PM
perki48's Avatar
perki48
perki48 is online now
Received 4,100 Likes on 1,913 Posts
Chirping sound like a "bird" is usually head gasket.
Old 08-08-2016, 04:09 PM
STLBagger's Avatar
STLBagger
Check out the video to hear the noise
STLBagger's Avatar
STLBagger
All tight
Quick Reply: Chirping engine noise?
