Broke the post on my tourpack antenna ...
Old 08-21-2016, 09:37 AM
voudoujoe's Avatar
voudoujoe
voudoujoe is offline
Default Broke the post on my tourpack antenna ...
I have a 2015 Ultra with the antennas on the tourpack. In trying to unscrew the stock antenna, rather than unscrewing, the antenna stud sheered off.
Unsuccessfully tried to grip what was left to unscrew it. Then it occurred to me - maybe it doesn't unscrew.
Does anyone know how to remove this? It is part #51 in the image below.
It looks like it should screw out and is just stuck. So, I'm thinking an Easy Out should work. Does anyone know for sure?
Advice?
Old 08-21-2016, 01:05 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
On my 14 FLHTK, I lost the CB antenna and the stud. The stud did screw into the light assembly and the base of the antenna. I wonder if somebody used red Loctite on the stud? The replacement stud I used was P/N 76000166
The following 2 users liked this post by 14GuineaPig:
Damo222 (08-22-2016), voudoujoe (08-21-2016)
Old 08-21-2016, 02:11 PM
Stang951's Avatar
Stang951
Stang951 is offline
There is a set screw on the older TP's that hold the antenna studs in. I cant tell by that small pic, but I do see something from the inside of the TP where the antenna is. That may be your ticket
Look at 23, 52 and 4
voudoujoe (08-22-2016)
Old 08-21-2016, 03:40 PM
W€€DWacker's Avatar
W€€DWacker
W€€DWacker is offline
Same thing happened to me in the same side. 2014 FLHTK. For now I've left it. I don't have use for my antennas. I think I'm going to take the light bar off of the pack and drill it out. Winter project.
Old 08-21-2016, 07:01 PM
greendragon52's Avatar
greendragon52
greendragon52 is offline
I had a '01 EGC and the antenna broke off at the base leaving nothing to grip on to. Bike was in for service and I asked the dealer to try and remove the stud. They wound up breaking the antenna housing and gluing it back together. My guess is that it is probably impossible to remove. Two choices, either look to replace the antenna housing block or change over to a fairing mounted antenna.
Old 08-21-2016, 11:58 PM
glcash's Avatar
glcash
glcash is offline
Advice?
Unscrew #52 on diagram and then #51 broken part will slide out upward.
Old 08-22-2016, 12:37 AM
voudoujoe's Avatar
voudoujoe
Thanks, Stang951. I think you are right.
I took apart the assembly and when I wiggle the antenna assembly (52), the stud (51) rocks back and forth. I tried to unscrew 52, but only with my hand as there are threads and I didn't want to trash it with pliers (its round, no wrench). I couldn't get it to come loose. There's not a set screw I can see and there isn't one on the drawing.
The place were they connect is inside the lamp assembly (29) that doesn't come apart.
I'm going to go to HD and get the stud (51) and look at the assembly (52). Maybe then I'll be able to tell how to get them apart. I think maybe 52 screws into 51. It looks like it could be that way in the drawing.
Old 08-22-2016, 05:26 AM
6530mask's Avatar
6530mask
6530mask is offline
good gen!
Old 08-22-2016, 05:51 AM
14GuineaPig
http://www.harley-davidson.com/app-c...ts/-J05757.PDF
The diagram on page 2 looks like the antenna stud might be pinned by the antenna plug assembly (parts 51 &52 in the diagram posted earlier)
Old 08-22-2016, 04:04 PM
voudoujoe's Avatar
voudoujoe
I searched on YouTube and found the following video that may be helpful.
2007 Harley Davidson tour-pak antenna replacement
https://www.youtube.com/watch?v=auDmYKxN2yc
On the 2007, the antenna assembly (52) does screw into the stud (51). I assume, based on the way the picture looks, HD hasn't changed teh basic design.
Quick Reply: Broke the post on my tourpack antenna ...
