Brake Lever REAL Hard to Mash!!
Because the ABS system is not supposed to fail in a way the prevents the normal braking operation from working properly. Maintenance issue or not causing the failures, it's a safety issue the way it fails. Most guys I've seen have an issue say the front brake lever is rock solid and no front brakes. If that happened on a pickup truck or passenger car and started occurring more frequently, there would be a recall. Harley needs to recall the ABS module.
The following 2 users liked this post by Buelligan666:
Campy Roadie (10-09-2016),
qtrracer (10-09-2016)
And tell us, why is the abs failure only a problem from 2008~2011? Given your comment, it must be that owners of 2008~2011 bikes dont change fluid per schedule but owners of 2012+ bikes do? And why does MOCO advertise "if abs failure occurs, braking will resume to normal, non-abs braking".
The following 2 users liked this post by KumaRide:
Page 269 of my 2015 SGS owners manual "Perform the service and maintenance operations as indicated in the regular service interval table. Lack of regular maintenance at the recommended intervals can affect the safe operation of your motorcycle, which could result in death or serious injury. (00010a)"
So I guess they did update the owners manual! I don't have an older version to see if that is already there.
Thats very specific. (sarcasm) And on pg 269 you say.... lol
Moco used to advertise that abs will resort to normal braking if abs fails. Dont know if they still do. And why did the problem stop after a certain year?
Last time I was at my dealer getting some work done, they asked if I wanted brake fluid flushed and told me it should be done every two years. I went for it but thought it was a bit odd given that in cars you don't often hear of people flushing their brake fluid. They had posters up in the service area as well reminding people to flush the fluid, must be pushing this given the issues that are being mentioned here.
Here are the MoCo vids advertising abs. They discuss self-diags and if diags fail, the bike will behave like a non-abs bike. Given the MoCo's statement if abs diags fail normal braking will resume, the diags appear to only check the electrical/electronics portion of abs. Not the hydraulics or abs module. My guess is, abs diags only check bearings to pickup sensors to ecm. Maybe the abs electronic abs controller to some extent, maybe not. If it did check the electronics abs module, it should exercise the solenoids which would exercise the abs plungers/valves. At this point the diags should notice the valves/plungers are not working properly.
Start at 7:05
Start at 9:10
Choopy
05-23-2015 12:33 AM
NH_Tim
04-24-2015 03:02 PM
Choopy
04-24-2014 12:21 AM
