Rebuilding Air Shocks
Old 10-18-2016, 04:27 PM
roundy's Avatar
roundy
roundy is offline
Default Rebuilding Air Shocks
So I am in the process of rebuilding the air shocks on my 2002 Road King (70k miles). I've made the tool to compress, drained the oil and ready to get compressing following this guide; http://xlforum.net/vbportal/forums/s....php?t=1356875
Only one thing I am not sure about, should I have the circlip out before I compress or should it be in place?
Cheers!
PeterV (10-19-2016)
Old 10-18-2016, 05:04 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Red face
What is it about your shocks that prompts you to rebuild them? If they are original then with that mileage they are also quite probably worn out!
Old 10-18-2016, 05:31 PM
roundy's Avatar
roundy
roundy is offline
Hey dude, trying to chase down this knock; https://www.hdforums.com/forum/touring-models/1141251-road-king-suspension-knock.html
From what I can tell I have a slight weap from the oil seal on the shock I think is causing the noise. Using a thread from XL forum to rebuild (taken from a Goldwing site. What can wear out apart from the oil and seals?
Old 10-18-2016, 08:26 PM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
Probably easiest to find a next to new take off set in the classifieds or ebay. When I blew a seal on my 06, I picked up a set taken off when the bike was new for $50.
Just a thought.
Old 10-18-2016, 09:01 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I wish I could help, but I am just learning about these shocks myself.
I only recently learned that they were even re-buildable, and I learned it reading on this very forum. I also found out that they are the same Air Shock that Honda ran on their Gold Wings for many years. Though they are by no means the worlds greatest shock, I do know with some proper maintenance, and the right fluids, people get decent results. Especially if your like me and NEED a shock with LOTS of very simple adjustment due to very diverse weight changes. Please keep us posted with info you learn. I will eventually send mine in for shortening and get rid of my Pingle Blocks, but until I get off the pot, I would love to hear what's working for folks.
Old 10-18-2016, 09:29 PM
rocket23's Avatar
rocket23
rocket23 is offline
Received 3,608 Likes on 2,863 Posts
still looking for a cheapo bicycle pump for my left side bag......only thing that's missing.
Old 10-19-2016, 02:09 AM
roundy's Avatar
roundy
roundy is offline
Second hand was my original avenue, and yes they can be had pretty cheap.....but not in the UK :-( Parts like this are not very common at all, by the time I add shipping I am up to around $100 - which again isn't crazy money, but for £13 worth of seals and some fluid I'd rather have a go - I like wrenching things :-)
Old 10-19-2016, 04:44 AM
hotrod351's Avatar
hotrod351
hotrod351 is offline
nice that someone took the time to take pictures and post how to.
Old 10-19-2016, 06:12 AM
Goose_NC's Avatar
Goose_NC
Goose_NC is online now
Received 4,265 Likes on 1,999 Posts
Progressive and Harley air shock pumps have what they call a no loss air pump. As you are screwing it one, it will seal first, then compress the schrader valve stem, opening it. When unscrewing, it will release and close the shock air valve before the seal releases. Resulting in no air loss to the shock. A progressive air shock gauge lasted me for $15 years. Kept it in a padded bag in my saddle bag most of the time.
Perhaps you could adjust the bicycle pump fittings to do the same function? I've never tried that.
Old 10-19-2016, 04:04 PM
roundy's Avatar
roundy
roundy is offline
Got the shock compressed and the top cap off, can't seem to budge the oil seal. Tried the BFH method and no joy, leaving it to soak in a little WD over night as I can see a small rust ring by the seal - potentially on the metal parts below.
Ozark Joe
EVO
02-26-2016 08:24 PM
rwven
2014-2023 Touring Models
02-25-2016 11:21 AM
CharruaHD
11-11-2012 05:19 PM
brushbuster
09-12-2012 12:57 AM
Musky
03-16-2006 12:17 AM
Quick Reply: Rebuilding Air Shocks
