Front Brake lever extremely hard
Yours is THE standard symptom for ABS control module failure. There is a chance it is something else but not likely. Start saving up, only $700 to about $1000 to get your front brake back. If it is the ABS, be absolutely sure to report it to NHTSA, there is a lot of this going around and Harley needs to have a fire built under it for a fix.
Responses have mentioned ABS and you may not even have ABS.
You guys are correct.. My BAD!
I have a 2010 Ultra Classic Limited.
As far as the front brake control, UPDATE.. I looked through the level bubble on the master cylinder and it showed as not being totally full. I purchased some new fluid "DOT4" and filled it to the top. For now that seems to have done the trick. I know that I am due for a at least a front brake job where I will totally replace the brake fluid with some new stuff; hopefully the ABS keeps working correctly.
Fully flushing the fluid requires that the ABS pump be cycled and that requires the Harley maintenance computer. A standard "shade tree" flush leaves the old and possibly contaminated fluid in the ABS unit. Currently Harley is blaming failure to perform the recommended flush every 2 years as contributing to/causing the ABS failure.
Ride safe.
