Adaptor Needed Micro Start to Battery tender
In need of an adaptor that will convert the Micro Start XP-1 connection on my bike to the SAE connector for a Battery Tender. They make that adaptor for the older XP-1 but not the newer version.
I really do not want both cables as a separate connection on my battery posts. The post already have 2 other connections attached to them and the threaded bolt on the terminals is running out of thread and no room to use longer bolt.
Any ideas will be appreciated.
battery tender pigtails usually have fuses inline- too much power applied and they go poof
so if you were thinking about starting your bike through 2 small wires...maybe that is why they stopped supplying the cables.
jumping:
in general, a duff battery can place a heavy load on your bikes charging system.
jumping a dead bike will require the charging system to supply power to the bike, lights and duff battery- perhaps exceeding the capabilities and killing your stator or voltage regulator...or both.
a $100 battery problem becomes a $600 charging system problem.
if you are just charging your xp to give laptop or phone power reserve, then that's a different thing and even connected through the fused pigtail should be ok
mike
jumping:
mike
jumping:
mike
jumping:
mike
Just thought someone else ran into this and found where I could buy the newer adaptor. Antigravity ( Micro Start ) does not have one.
The reason for the adaptor is so I can plug the battery tender into the Micro Start cable .
By the way the cable for the Micro Start is also fused to prevent overload
pt4u2nv - Go to the Antigravity site, and go to accessories, they sale a jumper cable for your XP1.
It hooks up to your Battery and has a built on adapter that allows the XP1 to plug into it for jump
starting your Bike. "DO NOT use the battery tender cable to jump start the Bike" it will burn the wires.
Antigravity has an accessory that will let you use a battery tender to charge the battery of your
Bike, using the accessory jump start cable. It should cost about $20.oo plus shipping & taxes.
seems to be an impasse.
if your hold up is that you don't want to add wires at the battery-
you can take your wires and attach the + to the starter terminal ( where the battery cable connects) and attach the - to one of the starter mounting lugs.
Mike
Mike
pt4u2nv (01-19-2017)
Received 4,617 Likes
I made a 10ga pigtail with standard SAE connector for attaching to the battery, can plug most tenders and accessories into it, and made an adapter for my jump battery to plug into the SAE connector. Mine uses EC5 connectors, common on Li jumper batteries, but don't know what that stand alone Anti Gravity uses. SAE and EC5 connectors are plentiful on Amazon.com
My home made adapter parts - I got 12" cables with SAE connectors on both ends, just cut one off, couldn't find just the plug, and this way they're heat sealed, much neater. I put the braided sleeving over the wires, held at the ends by the internal adhesive heat shrink. I haven't needed that roll of 10awg wire yet. The red heat shrink is for identifying the positive terminal for the battery. A little cheaper for one bike, way cheaper if you have several like I do.
