Radio Fuse keeps blowing? SOLVED!
Old 08-02-2007, 02:31 PM
Bryan TTM's Avatar
Bryan TTM
Bryan TTM is offline
Default RE: Radio Fuse keeps blowing?
there is....take em off one at a time and add some metal to the bends with a welder...you know, brace the stress areas with big globs of weld and metal
Old 08-02-2007, 07:19 PM
gilbos440rt's Avatar
gilbos440rt
gilbos440rt is offline
It's call a Road Glide [sm=happybounce.gif]just kidding! I'd wrap a piece of 1/8" flat stock around the problem area, weld the break like Bryan said then gusset it with the flat stock and weld it, that should solve the problem, ortry Road Glide option, same color though because it's KILLER!!! Sharp bike fryeca, when you're ready to do the I-Pod thing givemy mountsa look
Old 08-03-2007, 06:28 AM
0204665J's Avatar
0204665J
0204665J is offline
Just got my bike back this week. Both brackets were broken and chapped my wires. 6 in all had to be heat shinked. Not a good situation when these brackets break and skin up your wiring.
Old 08-03-2007, 04:18 PM
fryeca's Avatar
fryeca
fryeca is offline
Hey gilbos440rt
Just looked at your photobucket pics...nice StreetGlide rear fender ya got there!
Old 08-03-2007, 05:30 PM
gilbos440rt
Thanks, I needed something back there
Old 05-04-2010, 02:33 PM
smokintitan's Avatar
smokintitan
smokintitan is offline
Stage I
hey my radio memory fuse keeps blowing,, even when the ignition switch is off.. as soon as i touch it with a new fuse she blows.. any ideas
Old 05-29-2012, 09:43 PM
Zhallart's Avatar
Zhallart
Zhallart is offline
6th Gear
Default memory fuse
Funny how the dealership has never heard of these common problems.
I too have a blown memory fuse. Replaced it and it worked for a few minutes.
thought I had it fixed so I didn't watch it closely. Not sure if it blew when I started it or turned on the switch - maybe even rode it. Get some more fuses and try to isolate the failure point.
Put in a new battery (HD) recently - how could taking off the seat, as someone asked, be a problem?
Thanks
Art - aeh@dslextreme.com
Old 04-01-2014, 12:46 PM
Hdchromeman's Avatar
Hdchromeman
Hdchromeman is offline
1st Gear
Radio memory fuse blew on my 07 ultra. Used the forum advice. Pulled the Fairing and found a very small frayed wire on the radio line just as the forum suggested. A little electrical tape and it is good to go! Thank you forum!!!
Old 04-27-2015, 09:02 PM
luckyOne's Avatar
luckyOne
luckyOne is offline
Hey just saw your post and I have a very problem with mine too but I just installed a brand new radio and I am not using the factory radio at all and I am still blowing fuse but it only happens when i hit the turn signal, 3 fuses blow, radio power, radio mem, and accy fuse can anybody point me in the right direction
Old 09-12-2015, 08:16 PM
JoshFLHX's Avatar
JoshFLHX
JoshFLHX is offline
Stage I
Originally Posted by fryeca
My radio went dead a couple of days ago, I found the Radio MEM (memory) fuse had blown. I went to the dealer and they said that they had never heard of that fuse going before? They gave me a couple of spare fuses just in case it blew again.
Well it blew again; and again. Doesn't matter if the bike is running or sitting overnight in the garage. It doesn't go right away, seems to take about a day then BAM!
Anyone else have a similar problem or fix?
Hey did you ever figure out what the issue was? My 07 StreetGlide is doing the same thing and I looked behind the fairing and couldn't find anything. Let me know please I'm at a loss
Quick Reply: Radio Fuse keeps blowing? SOLVED!
