"DIY MODS" and TRICKS to SAVE $$$$$$
Old 11-22-2014, 12:50 PM
fer79's Avatar
fer79
fer79 is offline
Digital waterproof voltmeter
Ebay : 12V-24V Waterproof Car Motorcycle LED DC Digital Display Voltmeter For monitor
Price: $10.39
  #1652
Old 11-22-2014, 07:05 PM
White Ice's Avatar
White Ice
White Ice is offline
You mounted a voltmeter above your voltmeter?
The following 2 users liked this post by White Ice:
Alex Anders (01-16-2021), rblahetka (09-15-2019)
  #1653
Old 11-22-2014, 07:38 PM
GregGillette's Avatar
GregGillette
GregGillette is offline
Looks like stock analog meter is accurate. I will pass on that mod
  #1654
Old 11-22-2014, 08:11 PM
04ctd's Avatar
04ctd
04ctd is offline
what did you use to cut the hole, a squirrel?
IDK, that might be useful.
my buddies SG was charging enough to stay running, but not enough to re-crank when you got where you were going, was'nt really noticeable on the analog meter.
  #1655
Old 11-22-2014, 10:09 PM
Frank the Real Biker's Avatar
Frank the Real Biker is offline
I'll probably do that to my bike. Yeah, it's a little redundant, but the more accurate information you have about what's going on with your machine the better. Analog gauges aren't always accurate. They might be consistent...but not necessarily accurate. If your analog gauge suddenly shows higher or lower it might be good to look at the digital gauge and know exactly how much higher or lower to help with road-side trouble shooting.
Yup...the more I think about it, the more I think I'll do the mod myself.
  #1656
Old 11-23-2014, 07:06 AM
fer79's Avatar
fer79
fer79 is offline
Yes it is more accurate than the analog hd
is very small, very discreet
the hole is not very nice, the squirrel had no power. Hahaha
use drill and round file to enlarge the hole
  #1657
Old 11-24-2014, 09:33 AM
jamess71's Avatar
jamess71
jamess71 is offline
Yes I like it too. I might do this one too. How about replacing the analog voltmeter with an oil temp gauge? That would be nice.
  #1658
Old 11-24-2014, 06:30 PM
White Ice's Avatar
White Ice
Most people replace the Air Temp gauge with an Oil Temp gauge. If you want the accuracy and look of digital, replace all the gauges with Dakota Digital gauge package.
  #1659
Old 11-25-2014, 10:26 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
Yes it is more accurate than the analog..
on many models there is voltage drop through the wiring from the battery to the fairing- on some models ( my '95) the Vd was over a volt and could be more depending on the lighting load....even turn signal operation.
while the needle might be waggling back and forth on turns or the horn...the voltage at the battery was fine- DC doesn;t travel well.
so not an accurate indication of battery condition.
Those really concerned with battery state of charge, can always wire the voltmeter to the battery ( fused) and use a relay to switch this on and off with the ignition.
That's what i did.
Mike
  #1660
Old 12-05-2014, 09:07 AM
mahammond's Avatar
mahammond
mahammond is offline
Stage III
Default New Member w/ Several Road King Upgrades
Greetings from NC...love this thread...got some great ideas!!
I"m going to post pix of several upgrades to my 02 Road King...some inexpensive...some definitely not!!
Here's my list...reply if you want to learn more about any particular one.
- Cam upgrade with true dual Porker Pipe turn downs. (Pic included)
- True Reverse gear (have matching Voyager Trike Kit that is FOR SALE)
- K&N Filter
- Hoffe Quadzilla Faring w/ XM2Go (pic included)
- USB/Cigarette Lighter Power supply
- Solid State digital Volt meter (pic included)
- Shark 100W rear speakers on King Tour Pack luggage rack (pic included)
- Stebel Nautilus Air Horn (pic included)
- Rear Flashing Brake light bar w/ Turn Signal
- Time Out Camper
Thnx...Mark
Attached Thumbnails  "DIY MODS" and TRICKS to SAVE $$$$$$-hoffequadzilla.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-porker-pipes.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-volt-meter.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-shark-rear-speakers.jpg    "DIY MODS" and TRICKS to SAVE $$$$$$-stebel-air-horn.jpg
Quick Reply: "DIY MODS" and TRICKS to SAVE $$$$$$
