Another Multiple Choice Oil Question
Old 01-05-2008, 05:36 PM
MFA's Avatar
MFA
MFA is offline
Default Another Multiple Choice Oil Question
It is time for my 1000 mile oil change. I am going synthetic (my dealer says it is ok at this time). The dealer claims you can use the same HD Syn3 oil in the enigine, transmission, and the chaincase. I know some people have been using combinations of Mobil 1 synthetic 20w50 for Engine, Mobil 1 75w90 Syn gear oil for the trasmission, and HD Formula + Transmission and Primary Lub for the Chaincase. Now for the multiple choice questions.
1- Can I use Mobil 1 Syn 20w50 for all three?
2- Can I use Mobil 1 Syn 20w50 for engine, Mobil 1 75w90 for Transmission, and Mobil 1 75w90 for Chaincase
3- Can I use Mobil 1 Syn 20w50 for engine, Mobil 1 Syn 20w50 for Transmission, and Mobil 1 75w90 for Chaincase
4- Can I use Mobil 1 Syn 20w50 for engine, Mobil 1 Syn 75w90 for Transmission, and Mobil 1 Syn 20w50 for Chaincase
4- all of the above.
Thanks.
Old 01-05-2008, 05:41 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
Default RE: Another Multiple Choice Oil Question
4...
I use AMSOIL 20w50 for the engine & primary & 75W90 in the trans
Old 01-05-2008, 05:45 PM
hitone's Avatar
hitone
hitone is offline
Based on everything I have read, I would suggest choice #4. is the best of your options. I personally have had great results in my 2007 Street Glide with Amsoil 20W50 in the motor, Harleys chaincase lube in the chaincase (I don't remember the name of it) and Redline Heavy Duty Shockproof in the tranny.
I am sure your Mobil 1 choice #4 will be a great choice as well.
Ride safe and enjoy!
Old 01-05-2008, 05:51 PM
Facetious1's Avatar
Facetious1
Facetious1 is offline
I would definitly throw the heavier wt in the tranny... helps with the knocking sound on shifting... and overall -better coating on the gears...[sm=bounceybounce.gif]
Old 01-05-2008, 05:57 PM
BLACK 3's Avatar
BLACK 3
BLACK 3 is offline
ORIGINAL: SoCal_Pappy
4...
same here or try this
amsoil 20w50 for engine
amsoil atf for primary
amsoil 75w90 for trans
Old 01-05-2008, 06:01 PM
tmitchellof PG's Avatar
tmitchellof PG
tmitchellof PG is offline
I put Mobile 1, V Twin 20w50 in the engine and primary. Mobile 1 75w90 gear lube in the tranny.
When you say Mobile 1 20W50, I assume you mean the V twin version. In the regular Mobil 1, I think the closest you can get is 15W50.
Tom
Old 01-05-2008, 06:55 PM
Duracell's Avatar
Duracell
Duracell is offline
Received 1,654 Likes on 580 Posts
ORIGINAL: Shawn ultra
4...
Same here. I'm sure Mobile 1 is just as good but I have a locale guy that keeps Amsoil in stock so it's just convenient. As long as you are changing your fluidson a regular scheduleyou'll be fine.
Old 01-05-2008, 07:34 PM
jakedog's Avatar
jakedog
jakedog is offline
Mobil 1 V Twin 20w50 Engine
Mobil 1 75w90 transmission
Formula + for Primary.....
Old 01-05-2008, 07:42 PM
mn.roadking's Avatar
mn.roadking
mn.roadking is offline
Why wouldn't you use what HD recommends? Are you trying to save money? You know the SYN3 will work.
Old 01-05-2008, 07:48 PM
biz44's Avatar
biz44
biz44 is offline
Just go with the Red Line Big Twin 20W50 PowerPack at Racer Supply. I think they are still a sponsor here and you can get a few % off if you tell them you learned about the deal here!
I used this in my FXSTD-SE and it ran cooler and quieter....shifted smoother also, and all I had to do was think about neutral, and the green light would come on!
This is a super deal
Quick Reply: Another Multiple Choice Oil Question
