103" Big Bore Kit
103" Big Bore Kit
I was at the stealership today working out the details for Stage I install and download. They are having a sale on the big bore kit. Includes the big bore kit, SEAC, SERT and labor to install and tune for $1695.81. That is tax, title and license out the door. What do ya'll think about the deal?
RE: 103" Big Bore Kit
be sure you get a quote on your exhaust system before you have the work started. It may sound like a great deal now, but if they try to sell you a 1500.00 exhaust system then the good deal just went down the drain.
Good luck with your build. I hope all works out for you well.
This is the stage 2 big bore straight from the 2008 screamin eagle catalog.
I was quoted $1500.00 for the same exact stage at my dealership but decided to go for the 103" high output route.
The Stage II Big Bore Kit provides the parts you need to
increase the horsepower of your EFI-equipped model. The
50-state street legal kit increases the displacement of your
Twin Cam-equipped model from 96 cubic inches (1584cc)
to 103 cubic inches (1690cc). Includes Stage II (SE-255)
cams, 3-7/8" Big Bore cylinders, 3-7/8" Big Bore flat top
pistons, clips, and a Stage I Air Cleaner Kit with one-piece
back plate, integral breathers, all mounting hardware,
and gaskets. Also includes a high performance clutch
spring. Separate purchase of cam spacers is required. See
manual for proper procedure and cam spacer part numbers.
Requires separate purchase of primary cover gasket. Not all
components shown. 49-state kits include catalyst mufflers,
and California kits are street legal on California pollution
controlled vehicles when used with Original Equipment
mufflers. All EFI-equipped models require ECM calibration*
(priced separately)
. Regulatory approvals pending for
’08 California kits.
*Recalibration is required for proper installation, and will
allow engine to rev to 6200 RPM. See dealer for details.
Labor cost not included.
Fits 49-state ’08 Touring models. Not street
legal in California.*
Available August 2007.
27532-08
Black. $1,199.95
27533-08 Silver. $1,199.95I was quoted $1500.00 for the same exact stage at my dealership but decided to go for the 103" high output route.
Stealer's 103 kit will give you marginal improvement over stock numbers. ALL good builds begin with heads being re-worked.
Poke around here... http://www.head-quarters-usa.com/ushome.html
-and here -
http://www.nightrider.com/biketech/index.htm
-and here -
I'll second the , becareful on the price of the exhaust.
That could make or brakeyour deal.
One of the hardest things I've had to do, is to set a limit for the steps I take towards the finished setup. One of the things that makes it so hard is, I put so many miles on the bike that most of the new and newer parts are getting tired by the time I finish with all the goals. Plus the goals seem to change as I go as well. Next thing you know the bike is 10 plus years old.
In a perfect world, ( I don't live in one! ), there would be pleanty of money and time to bring the perfect change to one bike at a time, while riding the last bike that you just made perfect. lol
good luck with your goals
chappy
chappy
As for the mufflers... With a download I am limited to SE only. But if I go with the big bore and the SERT I can go with any muffler without affecting my warranty. Vance & Hines are around $400. I asked if I could buy parts online and have them install. If I go that route, I will forfeit my extended warranty. Can't really blame them for that, they gotta make the money somewhere.
