03 FLHTCI NOT CHARGING
My 03 electra glide classic is not charging, I took the battery to Auto Zone and had them put a load on the battery and it came back good. I am assuming that the voltage regulator would be the next part to eliminate, but I don't know how to check it. Can anyone help me with this? Thanks in advance
RE: 03 FLHTCI NOT CHARGING
Take a look at the "Do It Yourself" (electrical and lighting) part of the HDF and you will find two excellent stickys on checking your charging system and identifying the problem. They appear to be right out of the HD Electronics Diagnostic Manual.
https://www.hdforums.com/forumid_243/tt.htm
ORIGINAL: 03 FLHTCI
www.expertvillage.com/video-series/1207_motorcycle-maintenance.htm
Peter
The last timeI changed my stator, I also changed the regulator. The mechanic that changed the stator recomended thatI change the battery also. Something about an old battery that doesn't want to accept the full amount of charge the stator is trying to push into the battery, making the stator go defective over time.
Bayerboy64
10-11-2018 09:20 PM
