Charging system
Old Aug 18, 2007 | 04:22 PM
98UltraEvo's Avatar
98UltraEvo
Default Charging system
1998 Ultra Classic with charging issues. Battery went dead, boosted it and got it home, went and bought new HD battery.
The problem is the volt meter is showing only 10 volts, meter hooked to the battery is reading 12.50 volts.
Not really sure what else to look at, looking for help in checking the charging system regulator, generator or any help.
[&o] Ontario Canada.
Thanks,
John
Old Aug 18, 2007 | 05:18 PM
svionttm's Avatar
svionttm
6th Gear
Default RE: Charging system
I had the same thing happen on July 4th at the beach. Bought a battery but voltmeter was still at 10. It was the stator and alternator. I have a 05 ultra with 40,000 miles.
Old Aug 18, 2007 | 05:35 PM
gargoyle's Avatar
gargoyle
Had the same problem last week volt meter said 11 or so ended up being my stator do a search on itand you will find out how to check the stator and regulator. hope yours is the reg if it's the stator hope you have a manul or some cashput back good luck.
Old Aug 19, 2007 | 02:30 AM
Newhog's Avatar
Newhog
To check the stator romove your clutch cover and smell the inside, if it smells horriable it's probably a bad stator. My buddy's went bad on the way to Sturgis, it was about a $400 repair at the Harley dealer and it took about 3 hours.
Old Aug 19, 2007 | 01:55 PM
98UltraEvo's Avatar
98UltraEvo
Thanks for the info, did some checking as per charge system testing. It is telling me that the regulator is cooked, any help in
replacing it first locating and removal of it?
tsmithopt
Oct 9, 2019 01:44 PM
frankharley07
Electrical/Lighting/Alarm
Aug 10, 2016 06:42 AM
sharkharleyrider
Jul 23, 2013 01:09 PM
trickin addixion
Oct 19, 2010 07:30 PM
Astro
Oct 10, 2010 07:08 PM
