120 days on new stator?
Old Oct 19, 2010 | 02:44 PM
trickin addixion's Avatar
trickin addixion
Default 120 days on new stator?
Just replaced stator and regulator 120 days ago and last week lost volts. Tested the stator and found the stator not putting out anything. Today called Harley and they said 90 days is all they will stand behind thier stators. I done all the tests when I put the new stator in and everything tests ok. My question, is this normal and am I going to have to replace the stator every 120 days?
Old Oct 19, 2010 | 03:10 PM
1931jamesw's Avatar
1931jamesw
Not normal but probably not unheard of. Are you sure your battery is good? Ive heard of guys knocking out their whole charging system just trying to get every last little bit of life out of their battery.
Old Oct 19, 2010 | 05:07 PM
trickin addixion
Battery checked ok at that time not sure bout now. Waiting on battery to charge on the charger now. Drained the battery pretty low before I noticed it wasnt charging.
Old Oct 19, 2010 | 06:40 PM
1931jamesw's Avatar
1931jamesw
Any bad spots on the wire that runs from your voltage regulator to your battery or any other wires pertaining to the charging system?
Old Oct 19, 2010 | 06:42 PM
Faast Ed's Avatar
Faast Ed
What kind of primary fluid are you running?
Old Oct 19, 2010 | 06:44 PM
WZDADS's Avatar
WZDADS
I had a problem similar to yours but it was long after 120 some days, ended up being all the magnets on the rotor came loose and were bunched up....
Old Oct 19, 2010 | 06:57 PM
WZDADS's Avatar
WZDADS
Oh, I just remembered, an easy way to tell if it's the stator or not is to pull the primary chain inspection cover, the smell of the burnt stator will give it away.
Old Oct 19, 2010 | 07:27 PM
trickin addixion
I have been running just a type F tranny fluid but am going to change to something different. I suspect that may be part of the problem. Fixin to tear into it and check the magnets. They were in perfect condition 120 days ago. The primary definetly smelled burnt when I took the derby cover off. Battery checks fine with 12.58 volts charged and never drops below 10.7 when applying a load for 15 seconds and soon as the load is removed it comes back up to 12.4 volts.
Old Oct 19, 2010 | 07:30 PM
WZDADS's Avatar
WZDADS
If it stinks, it's the stator for sure....
TheBuckley
Jul 8, 2018 08:51 AM
Tomcatx5
Electrical/Lighting/Alarm
Oct 4, 2015 07:23 AM
jmg343
Jul 9, 2012 07:04 AM
rodney123456
Jun 15, 2011 07:27 PM
rwt
Sep 16, 2010 05:06 PM
