battery and charging system
Old Jun 15, 2011 | 04:53 PM
rodney123456's Avatar
rodney123456
Default battery and charging system
I thought i had a bad battery because my battery tender junior would not get off the red light charging changed it then 1 week later it is staying on again so i checked the voltage regulator out i thought put new one on still when i put the meter on the battery it still reads 12.7 volts when motor is reved up dont know what rpm so i ride around for about 1 hour come home check battery voltage 12.5 when motor not running. seems like it might be charging am i doing something wrong i thought it should read 13 or 14 volts when charging.i did put meter in the stator plug when running it is about 38 vac. How long will the battery last when stator not charging? 2000 softail deuce 38000 miles
Old Jun 15, 2011 | 05:05 PM
the blob's Avatar
the blob
yea you should get 13-14 volts at 2000 rpm. make sure all fuses and or circuit breakers are good. id ck all grounds as well. did you install the regulator properly? etc.
Old Jun 15, 2011 | 06:20 PM
rodney123456
i am at my wits end put multimeter in stator plug cranked it up putting out 22 vac idling reved it up putting out 40vac plugged it back in the voltage regulator checked voltage at the regulator wire at the circuit breaker to ground still 12.5 vdc what the hell that is a new regulator is there a way to check them .
Old Jun 15, 2011 | 06:26 PM
shortride's Avatar
shortride
I've said this so many times I've lost track. It's almost worthy of becoming a STICKY.
Anytime anyone thinks they may be having battery or charging issues, you should always have the battery load tested first. That generally doesn't cost anything and usually will keep you from become a part changer to fix a problem and save some money.
Rodney this may not apply to you but I thought I would just throught it out there anyhow.
Old Jun 15, 2011 | 07:00 PM
rodney123456
yea i put a battery in about 2 weeks ago just checked the voltage with the wire that goes to the circuit breaker from the voltage regulator disconnected when running it was about 2.3 volts
Old Jun 15, 2011 | 07:27 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Visit the DIY section of HD Forums in electrical section and it spells out the testing of the stator. The stator could be putting out voltage but no amps, one of the coils could have short.
Will-N-Missouri
Aug 26, 2023 08:38 PM
Stromhammar
Dec 21, 2022 07:57 PM
tsmithopt
Oct 9, 2019 01:44 PM
TheBuckley
Jul 8, 2018 08:51 AM
ryanlberg
Apr 11, 2012 04:10 PM
