Nitrogen in Tires
Nitrogen in Tires
I know I should do a search first... but... Smokey Mountain HD put Nitrogen in my tires when I bought the bike new... 32lbs front and 32 lbs rear according to my local dealership who did the $400 1,000 mile checkup and oil change.
My local Northwest Arkansas dealership has only heard of using Nitrogen, but doesn't know if the PSI is correct and can not put more nitrogen in the tires even if they wanted to...
They did say that they have heard not to add air to nitrogen filled tires.
What is the correct PSI for nitrogen? Is it a 1:1 relationship to air psi? If the dealership uses a regular air gauge, is 32psi enough or correct? This same dealership says that the front should have 35psi and rear should have 40psi for 2 up riding. Does anyone know of a dealership near Bentonville, AR that can put nitrogen into motorscooter tires?
Thank you in advance.
RE: Nitrogen in Tires
ORIGINAL: vettedog72
PSI is PSI. Does not matter what the gas is, PSI is the same for air or other gas. I can't answer the other questions.
So anyone else? Is the recommended PSI really 35 front and 40 in the rear? that's not what the service manual says. And can/should you add air to nitrogen filled tires?
IIRC, it's 1:1. It's more stable than air, and therefore doesn't fluctuate in pressure as the tire gets hotter. Havin' said that....in mah mind, it's a "gimmick" deal ta make ya pay a coupla more bucks to "top off" the tires. You can top 'em off with air, no problem.
I use Nitrogen in all my tires. Use exactly like air (1:1).
Do not mix air/Nitrogen...it defeats the purpose of the Nitrogen which is to keep moisture (present with air) out. This keeps your tires running cooler and supposedly longer wear life. We'll see about the longer wear life.
I bought my own cylinder and have not had to refill it yet. The cylinder cost $89.00 usd and to fill with Nitrogen costs me about $14.00 usd. Local service station charges $5.00 per tire and can only pump up to about 40 psi max. The main reason I have my own, is because I rebuild my boys shocks (atv/mx) on a very regular basis and need high pressure Nitrogen to refill. Local dealership was charging me $10.00 per shock every visit. That's some BS right there!
[IMG]local://upfiles/29179/63E1DE09762D4520A3BC1393ECE0DAE6.jpg[/IMG]
Just use ambient air (the stuff all around you) it is 78% Nitrogen anyway.
It is really kind of a stupid idea. It came about because it is more pressure stable when the temperature changes. Cama aboutinF1 racing. It helps keep the pressure ofyourtire incrementally more stable.
Realistically,It is negligable and really about as important or practicalas having a 1 megawatt alternater.
Nitrogen in tires is the 21 century "mystery oil" "snake oil"for tires. Nitrogen molecules are larger than what you would get out of using compressed air. All tires leak a little air over time, nitrogen being made up of larger molecules a tire will lose less psi. Also nitrogen is not effected by temperature as much as a tire filled with compressed air. A few oil change places around the area here are trying to sellpeople nitrogen for their tires, at a little extra cost. Kinda funny, but they have never asked me if I wanted nitrogen. I'm sure they get a kick out of B.S.ing so old lady on a fixed income out of a few more bucks.
I wouldn't worry about whats in your tires now, just top them off with air. It just won't be pure nitrogen.
ORIGINAL: SloChicken
