cam position sensor
Old 04-01-2008, 01:16 PM
rking2000's Avatar
rking2000
rking2000 is offline
Default cam position sensor
hey gang,
Got a 2000 rk,my engine light came on checked the diagnostic code 42 says its the camshaft positioner sensor.What i'm wondering is, is that magnetic like the speedo? I had tohave thecambearings,tensioners replacedlast summer(cam bearings raise hell when the go, by the way!) maybe it could have some trash or something like the speedo sensors do? Also noticed it is not in the wiring harness that it is supposed to be in, I think it may have been replaced before I bought the bike.Anybody ever replaced one?Also when I take the derby cover off I should'nt lose a bunch of oil should I?
Thanks in advance.
Old 04-01-2008, 01:34 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
Default RE: cam position sensor
Is the light staying on? If not, it is a historic code that will clear itself after 50 starts. These codes are sometimes caused when the bike kicks back when you are trying to start it. If the light is on, then the sensor is bad. You do not take the derby cover off to replace it. You take the cam cover off. You will only lose a few ounces of oil.
Old 04-02-2008, 10:53 AM
rking2000's Avatar
rking2000
the light comes on,i wait for the fuel pump to stop then fire it up. now sometimes it will come on and stay and other times it will go out.on occasion it acts like it dosn't want to start on the first time,it turns over and no go,then i'll wait a sec or two then it will fire up.
is the sensor a hard item to replace? i'm mechanically inclined,didn't know if there was speacial tools involved.
thanks
joelucci33
Exhaust System Topics
03-14-2011 02:48 PM
tmultra
01-30-2010 01:57 PM
coyotee
04-20-2009 08:38 AM
BLiZZNECK
11-13-2008 09:43 AM
2000lowrider
05-21-2008 08:13 AM
Quick Reply: cam position sensor
