garage door opener,reset button mod
Old 04-02-2008, 10:55 AM
Manfire's Avatar
Manfire
Manfire is offline
Default garage door opener,reset button mod
I was going to put the reset button next to the tach on my 08 ultra , similar to the way that the factory button is next to the speedo, but because the factory button is in a recess the button next to the tach wouldn't look quite the same. I was wondering where other people who have done this mod have put their button?
Old 04-02-2008, 11:15 AM
jbhawley's Avatar
jbhawley
jbhawley is offline
Default RE: garage door opener,reset button mod
I put my button on the side of the console, similar to the way a RK trip odometer button is positioned.
I mounted the garage door opener in the fairing w/ velcro, ran the wires along/under the tank and back up into the console. Works very good and looks factory to the novice.
I need to get some pics.
Old 04-02-2008, 11:23 AM
Fast Eddie's Avatar
Fast Eddie
Fast Eddie is offline
ORIGINAL: jbhawley
I didsimilar on my '07 Ultra (since sold):
Old 04-02-2008, 12:55 PM
Manfire's Avatar
Manfire
Manfire is offline
Fast Eddie: I like the way you put it on the 07 but the 08 console is different , it wouldn't work the same .
Old 04-02-2008, 01:01 PM
old.gezr's Avatar
old.gezr
old.gezr is offline
I put my openerunder the console of my SG and drilled a hole in the left side of the console for the button. Looks good, works good andeasily accessable for a battery change.
Old 04-02-2008, 05:14 PM
Fast Eddie's Avatar
Fast Eddie
ORIGINAL: Manfire
You are right. The '08is different. I have not tried it yet on the new one.
Old 04-02-2008, 05:28 PM
Wally's Avatar
Wally
Wally is offline
I just did mine yesterday. I put it next to the tach even thoughthere is no recess, it still looks just fine.
Old 04-02-2008, 08:21 PM
petty38's Avatar
petty38
petty38 is offline
I went to radio shack and got a button, ran the wires out from the remote to the button, velcored it to the inner faring and drilled a hole insidethe space where the speaker is from the top. Ran the button down thourgh the hole and used hot glue to secure it on the inside of the fairing. Works great and you can't see it unless you know it's there.
Old 04-02-2008, 08:48 PM
04harleyboy's Avatar
04harleyboy
04harleyboy is offline
I ran a relay and hooked it up to the high beam, both the relay and the remote are velcroed to the top of the radio, works great!
Old 04-07-2008, 05:04 PM
stevepacman's Avatar
stevepacman
stevepacman is offline
Ultra-geeky there Fast Eddie! I have 1 remote for the gate to my community and 1 for garage door. I velcroed one behind each side cover. I bought a water-tight aircraft pushbutton with a rubber boot and mounted it on the panel right behind the rear cylinder. (there is a 1/4" whole drilled from the factory) It's a lot cleaner and cheaper than H-D's xmitter/receiver method.
Quick Reply: garage door opener,reset button mod
