how do you change the AVC on radio
03-21-2009, 05:13 PM
Guys wondering how to change the AVC setting on the HK radio. I don't have a owners manual.
thanks,
James
03-21-2009, 05:24 PM
Push the left button (volume adjust) in instead of up or down. AVS adjustment is the last option in the list, so I think you will have to push it in about 4 times to get to AVS.
Then you just push the same button up or down to adjust.
Beary
03-21-2009, 05:39 PM
do I need to be in a menu mode? I just tried it and every time I pushed the left button in it just displayed different info like artest, station, etc.
03-21-2009, 06:06 PM
By pushing in the left button wile the radio is on it will go to Bass then Treble then displat then volume then AVS
03-21-2009, 06:26 PM
either my switch is broke, my radio is broke, or there is a wire loose. I can go up and down with the volume but pushing in does nothing.
03-21-2009, 06:58 PM
Just check edthe wiring and found that the switch is bad through the use of circuit tester
03-21-2009, 07:11 PM
Bummer. But atleast you found the problem. I have a service manual so If you need any info just shoot me a PM and I will hook you up.
03-21-2009, 07:38 PM
actually did some more trouble shooting and I think it is the radio. I got the switch to work and I checked the circuit from the radio and it appears to be working. I am going to try a software update and see if that does anything. thanks for the help. thanks for the offer but I bought a service manual last week and I am learning that it is good to have.
tkuligowski
2014-2023 Touring Models
24
08-02-2022 08:50 AM
davidwruth
General Topics/Tech Tips
05-09-2018 06:39 PM
DaddyKnuck
06-27-2015 06:40 AM
01XLH
04-26-2014 08:41 PM
yokdriver
03-15-2014 03:36 PM
05 ,
2009 ,
adjust ,
avc ,
blue ,
change ,
classic ,
flhx ,
glide ,
harley ,
radio ,
settings ,
street ,
time ,
ultra
