A Question Regarding Primary Fluid Capacity
I'm running Redline V-Twin Primary Fluid (aka MTL). The 2009 touring models spec 38oz (1qt + 6oz) for the primary. When I drained the old stuff out, I poured 1qt of new stuff in, and called it a day... That was about 2500 miles ago... Last night I took off the derby cover to check the level. With the bike upright, the oil level is slightly higher than the bottom of the clutch pack.
So my question is, how can that be if I only put in 32oz instead of the suggested 38oz?? And what is correct, 38oz or to the bottom of the clutch pack. Should I syphon a little out so that the level is at the very bottom of the clutch pack?
The reason that I wanted to check the fluid level is because lately I've been noticing an odd shifing feel when downshifting into 1st gear (not from nuetral though)...kinda like it wants to grind, but doesn't.
The clutch is adjusted pefectely, both at the basket and the barrel adjustment. The transmission fluid is also at a perfect level (RL Shockproof Heavy).
So the last thing I looked at was the primary fluid, and I found as described above...
The question I have is why would you put in one quart, 32 oz (knowing that the book calls for 38 oz) and call it a "day" and then ride it for 2500 miles?????
I hope you're not the local dealer's mechanic..
Sum'pin don't sound right.. I also use Red Line Primary and measured out the extra couple of oz when I do my changes. I haven't had any problems afterwards. Remember when you drain it, you don't ever get all of it, so maybe you still need 4-5 more ounces there.
The reason that I only put 32oz to begin with was because (1) everyone and their mother on this site said that the proper level is at the bottom of the clutch pack; and (2) because when I spoke to the Service Manager before I did the change, he said that they only put 1qt in all models, including the 09's.
And the reason that I just now checked the level is because, like I said, the shifting seems to be changing...
So my question is, should I put the whole 38oz, even if that puts the fluid level half way up the clutch basket? The manual is very clear that overfilling can cause problems, but makes no mention of underfilling.
Sorry, I'm not familiar with what the "quad ring/groove" is. Can you explain, or any pics? Thanks!
Oh, and yes, the 09's do have increased capacity, 38oz.
Thanks. One more Q for you...when you say that 38oz put it at the "proper level", what "proper level" are you referring to? Did the 38oz put it to the bottom of the clutch basket? Just want to be sure... Thanks again.
when i change the primary fluid on my 07, it calls for 38 oz as well. i put in a full qt, and then measure out 6 oz from another bottle. with the bike on the jiffy stand, it will not leak out, and the level is just above the ring gear on the clutch pack (as per spec)
are you changing the oil properly? ie. does the manual specify on the jiffy stand, straight up, etc? i don't know about the 09s, but i do know my 07 and this works for me.
Don't have an e-copy of the manual, sorry. With the clutch inspection cover removed, pic shows the fluid level barely touching the bottom lip of the opening (where the quad ring/groove is found). Hope that helps.
