Oil pan removal
Old 08-19-2009, 09:37 PM
teqsand's Avatar
teqsand
teqsand is offline
Big Kahuna HDF Member
Sorry for the hijack, but I was looking at the exhaust on the 09's... it looks like it would fit earlier years if you changed the oil pan.... the 09's have a notch in the pan to accommodate the exhaust.....
any thoughts....
Old 08-19-2009, 10:13 PM
Beeracuda's Avatar
Beeracuda
Beeracuda is offline
Well, I got it out tonight, rather easily. I did remove the swing arm pivot. Of course to do that, I also had to remove the exhaust. It wasn't a big deal, just going to add some more time to the installation.
Part of the problem may have been that the rubber bushings were definitely worn out and sagging. I was expecting to replace those on the bike since it does have 82,000 miles on the clock. I probably should replace the front mount as well.
It would have been much easier to suspend the bike, like the manual called for, but my hoist is 300 miles away in the race shop.
Now it's time to get everything cleaned up and get ready to put it back together. I was happy to see how clean the inside of the pan was. I hope to get everything done tomorrow.
Old 08-21-2009, 01:26 PM
Beeracuda's Avatar
Beeracuda
Got everything back together in about 3 hours and NO LEAKS! I've got to get a table lift. This getting down and up is tough on this old man.
Old 08-21-2009, 02:51 PM
beary's Avatar
beary
beary is offline
I'll bet its going to handle a lot better.
Old 08-21-2009, 03:26 PM
Beeracuda's Avatar
Beeracuda
I can already tell the difference in the short ride I had today. I'll put a quick 100 miles on it tonight and see how she does....
Old 11-04-2010, 10:01 AM
bubibear's Avatar
bubibear
bubibear is offline
Stage I
Angry Oil Pan Removal
I guess I'm my own worst enemy. Tried changing the oil (not the first time) on my 2000 Road King. Half way through, with the oil sump empty, I accidently dropped a small piece of rubber tubing down the dip stick opening. After trying for a day with flexible grabber, flash light, and sundry other tools, I thought about
removing the oil/tranny piece myself. Then I read this bulletin board, got my wifey to help push it up on the trailer and dragged it to the local Harley shop.
They still have it, but it'll be over $100 to do the work to remove the tubing.
Guess that's an expensive lesson learned. Next time, maybe I'll just take it to the shop in the first place. I'm getting to old for this frustration. To you all who are doing it yourself, you have my respect and best wishes. Go for it!
Bubibear
Billhd90
08-30-2015 02:03 PM
mdiede24
Engine Mechanical Topics
05-15-2015 10:35 AM
tandt
01-10-2012 07:44 PM
Moog Player
EVO
03-17-2011 08:30 AM
EdboIllinois
06-23-2008 06:44 PM
Quick Reply: Oil pan removal
