Low voltage on meter
My 91 Ultra Classic has problem. I notice my directional lights and brake lights were not working properly. I also noticed the voltage meter on dash was running below 12 volts. I hooked up battery charger, started bike and brought it up to 13 volts running. All the lights began to work properly. Is it the voltage regulator or problem with alternator. Any suggestions?
Thanks
Thanks
Received 4,309 Likes
If you charge the battery and it hold the charge overnight, Then chances are it's your voltage regulator or stator. With the bike running your lights should be bright and working properly even if the battery is weak since it would be drawing from the charging system. Check where your voltage regulator plugs into the stator. Sometimes the plugs get alittle loose and arc out. If that happends you need to replace both. If you still have the original voltage regulator and stator on a 91 bike, It might be time to replace them both.
My 95 also showed low voltage and for 2 years I chased it around. AS others have posted, search for charging sytem checks here on the forum. If everything including the battery check out, then pull your front fairing and check the connections on the main wiring harness. Yo 'll know which it is, it has three large red wires running to it and it goes from the left side of the fairng as you look into it to the right. It supplies the main power from the battery to the fuse panel. My connections were dirty and as a result if I played the radio and turned on the passing lights I got less than 12 volts on the guage. After cleaning the connections good and actually replacing one connection, all was back to 13.7 volts. I hope this helps.
I miss my old evo but love the new twinkie
Bubba
Bubba
Back to --BUY A REPAIR MANUAL FOR YOUR SPECIFIC BIKE---it tells you how to check a/c voltage and d/c voltage. It gives you the voltage curve--highs and lows for rpm settings. It also tell you how to eliminate out your problems. Do you own a digital volt meter? Checking voltage with a battery charger is like checking oil by tipping the bike on it's side instead of using the dip stick.
A manual is a great technical reference but who knows if his bike has been changed or tampered with or wiring altered. By all means the first tool one should buy is the service manual but sometimes a little experience from someone who has been there and done that may point him toward something and save him some time.
Good luck. Let us know what you find.
Bubba
Bubba
