2001 Tourpak, Fiberglass or plastic?
Old 12-30-2009, 09:36 PM
Sincecrazy's Avatar
Sincecrazy
Sincecrazy is offline
Default 2001 Tourpak, Fiberglass or plastic?
Im modifying a tourpak to hold some custom lights. Initially I thought it was made of fiberglass, but after cutting on it, I think it might be plastic. Anyone know what these are made of and any products that would bond fiberglass to plastic, if this is the case?
Old 12-30-2009, 09:40 PM
Glenn W's Avatar
Glenn W
Glenn W is offline
They are plastic now, likewise the lowers and fairings if so-equipped. Can't help ya with what adhesivs would be best, but I've seen folks post good info in the past so hang in there.
Old 12-30-2009, 10:48 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
wcsj55@yahoo.com is offline
Harley made both fiberglass and plastic trunks and saddlebags !!!
Old 12-31-2009, 12:22 AM
hog-doc's Avatar
hog-doc
hog-doc is offline
If its grey inside its fiberglass, if its black inside its ABS plastic. Autobody paint supply house should be able to set you up with products for either!
Old 12-31-2009, 06:41 AM
gabulldog's Avatar
gabulldog
gabulldog is offline
My 03 Ultra has glass bags & tour pack, at some point these guys went to an ABS type material. It is harder to repair the ABS and the materials are fairly expensive (at least the ones that work). Go to good auto body supply store.
Old 12-31-2009, 07:37 AM
Sincecrazy's Avatar
Sincecrazy
Its gray on the inside. and sands to white powder, and I havent noticed an ABS cast in it.
Old 12-31-2009, 08:04 AM
robbie52's Avatar
robbie52
robbie52 is offline
Fiberglass
Old 12-31-2009, 09:01 AM
Skip's Avatar
Skip
Skip is offline
Hate to cause conflict, but my 2001 FLHTC had some type of plastic bags.
Old 12-31-2009, 09:21 AM
gabulldog's Avatar
gabulldog
My 03 had been in an accident (not totaled) so the bags that were on it may/probably aren't the original, they are however factory in that they have HD paint and 03 stripes. It seams that somewhere around 01-04 they came with both types. I do know the glass bags are easier to repair and work somewhat better if you are putting extensions on the bottom than the ABS ones are. My experience has been that you have to really "scuff" the ABS to get any type of glue/filler to adhere to it. You will see the strains (when you get thru the gel coat)of glass cloth when you start working with them if they are glass bags/tour pack.
Old 12-31-2009, 10:02 AM
Glenn W's Avatar
Glenn W
Glenn W is offline
My apologies, I didn't know they'd gotten back into fiberglass, my bad.
Quick Reply: 2001 Tourpak, Fiberglass or plastic?
