Replacing torn air shock boots
Old 01-16-2010, 02:42 PM
Harleyinnc's Avatar
Harleyinnc
Harleyinnc is offline
Default Replacing torn air shock boots
If your air shock boots are torn, You can't buy replacements from Harley. You can get a Shock Mate Boot Kit part number SA1997 that works great. Just jack up the rear of your bike and remove the bottom shock bolt. Then cut the old boot off. The Shock Mate Boot come too long , So you'll need to cut about 6 ribs off of it. Then slide it on and secure it with tie wraps at each end.
You might be able to find these at your local auto parts store. I got mine from Amazon.com for $6.70 each. I bought 4 of them to have spares and save the shipping cost. If your a purest you can buy replacment boot from Honda for a GL1500 but there about $40 each
The picture is of them on my Ultra Classic.The link shows the boots on a GL1500. And the Shock Mate boots are made in the USA. They also come in 8 different colors.
http://oklahomawing.com/shock_boot.htm
Attached Thumbnails Replacing torn air shock boots-shockboot2.jpg   Replacing torn air shock boots-shockboot1.jpg
Old 01-16-2010, 03:17 PM
Rubbit's Avatar
Rubbit
Rubbit is offline
Good to know. If harley did sell a replacement, it would have cost $100.00.
Old 01-16-2010, 06:45 PM
02GhostRiderVA's Avatar
02GhostRiderVA
02GhostRiderVA is offline
Thanks for sharing this information. This is definitely a better option than duct tape. Rubbit is correct -- I couldn't imagine what Harley would have charged for the same item bearing their name.
Old 01-16-2010, 08:00 PM
GzrGlide's Avatar
GzrGlide
GzrGlide is offline
Sounds like the perfect excuse to buy new & better shocks!
Old 01-29-2010, 04:12 AM
BaZa's Avatar
BaZa
BaZa is offline
As the first post suggests that basicly what I did...
Steering rack boot kit:
Before
Make sure frame is supported before removing shock:
Cleaned shock, new boot and old cut off one.
Make sure oil does not leak from shock absorber.
Perfect fit plastic cable ties fitted:
Silicone smeared around the bottom:
Fitted and ready to go:
Old 01-29-2010, 06:46 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Wink
Hi BaZa and welcome from the UK!
Old 06-21-2014, 06:20 PM
Skip Hokanson's Avatar
Skip Hokanson
Skip Hokanson is offline
Stage II
do you cut the 6 ribs from the bottom or top
bansheebob1794
03-04-2017 04:58 PM
dfs14580
01-15-2014 03:13 PM
Sixty-Sicks
02-08-2012 09:25 PM
shakrr
06-03-2011 07:16 AM
mkultra
11-20-2006 09:35 PM
Quick Reply: Replacing torn air shock boots
