FLHX fork lock stuck
Old 01-25-2010, 04:59 PM
Live2ride247's Avatar
Live2ride247
Live2ride247 is offline
Default FLHX fork lock stuck
HELP!! My 2010 FLHX fork lock is stuck. The key worked when i locked it, but now it won't unlock. Is there a trick that I need to know? The manual say turn the key to the unlock position, and then rotate the ignition switch clockwise. What am I doing wrong?
Old 01-25-2010, 05:11 PM
Skip's Avatar
Skip
Skip is offline
Every once in awhile, I have to hold the bars all the way to the left to get the lock to release.
Old 01-25-2010, 05:13 PM
Skip's Avatar
Skip
Skip is offline
Who are you with in Iraq? One of my sons was there with the 4th ID in 2008-2009.
Old 01-25-2010, 05:17 PM
Moe55's Avatar
Moe55
Moe55 is offline
Skip is correct some times you will have to pull the bar to the left to unlock the forks. This does happen more if it has been sitting in the fork lock position for awhile.
Old 01-25-2010, 05:22 PM
Live2ride247
there is no pressure on the lock itself. The key wont turn in the ignition switch to the "unlock" position. I tried moving the handlebars back and forth, but the switch wont budge.
Just got back from Iraq on the 22nd. Sure is nice to be home.
Old 01-25-2010, 06:30 PM
1pkraft's Avatar
1pkraft
1pkraft is offline
Same thing happened to my wife's '09 FLHX - in the garage. I worked with the lock for nearly an hour before I could unlock it. Took it right to the Dealer who ordered a new lock assembly.
By the way, we didn't lock it again until the assembly was replaced.
Heard that HD had a problem with these last year or so but thought they had it figured out. Guess not since it's happended on your '10.
Old 01-25-2010, 06:34 PM
ashmarc's Avatar
ashmarc
ashmarc is offline
Not sure on this one.
Here's what I do know. A month after buying my '06 I had my entire ignition switch replaced by HD because I COULDN'T lock the forks......
Old 01-25-2010, 06:42 PM
twodollarbill's Avatar
twodollarbill
twodollarbill is offline
Do you have the correct key???
Old 01-25-2010, 06:45 PM
tmitchellof PG's Avatar
tmitchellof PG
tmitchellof PG is offline
Have you tried both keys? Maybe the one you are trying is out of round.
Tom
Old 01-25-2010, 07:23 PM
Live2ride247
I have tried all four keys, and none of them work. All four of them work on the saddle bags and the tour pack. The lock on the ignition switch will not turn with any of the keys. Pushing up on the lever under the lock doesn't do anything either.
Why are the dealers closed on Monday? GRRRRR!! They owe me a sunny day!! It isn't very often I get to ride in Washington in January, and I lost a day to a broken fork lock. Today was beautiful, too!
Quick Reply: FLHX fork lock stuck
