HD oil temp gauge test reults
Just finished installing a HD oil temp gauge in the fairing of my SG. I took the bike for a test ride yesterday which consisted of combined highway and through town stop and go traffic. The ride took about 45 minutes.
The outside temperature was 50 degrees.
I have a digital dipstick which I know is accurate because I put it in hot water on my stove and compared it to a cooking thermometer. Both read the same temp.
So what I did was compare the dip stick reading to the in dash gauge and there was a consistant difference of 25 to 30 degrees. The indash gauge read cooler.
The hotest the bike ran was only 205 on the dip stick, guess because of the outside temp and the fact that the bike runs richer in winter.
I'm thinking that the in dash gauge may still be accurate since there can be a difference in oil temp depending on where the reading is taken from. The sensor for the in dash gauge is in the oil pan in the hole next to the drain plug.
In reading old threads on oil temps I would shake my head wondering how some of your bike run so much cooler than mine in the hotter months but I think I have found the answer, they have the in dash gauge.
Was wondering if my location synopsis is correct. Anybody know?
Any thoughts?
Thanks,
Tom
Just wait until you ride in the rain! If you have the sending unit in the pan, it becomes very apparent how good the pan is at transfering heat, the oil temp will drop at 50 degrees or more. Realistically, the dipstick and the sending unit should sense the same temps as they are both measuring the oil temp in the pan. Might jst be a calibration issue with one or the other.
25 degrees seems to be quite a difference? I can see if you have a sensor just before a cooler....or just after one, but still. 25 degrees off?
I have a dip stick type thermometer. I ride in Florida (gets warm in the summer) and I have never gotten to where I feel my engine is threatened.
At least you can tell your oil temp all the time (within 25 degrees). Mine? I check every
couple gas stops (It is pretty accurate in the morning also for air temp).
chuck the mensh
chuck the mensh
chuck the mensh
chuck the mensh
BTW, no oil cooler on my bike.
