Best spark plugs?
Old 04-08-2010, 07:30 PM
mario medeiros's Avatar
mario medeiros
mario medeiros is offline
Default Best spark plugs?
What are the best plugs to run on my 2000 fi electra glide?Champion or ngk?Also what is the plugs # i should buy?Thanks
Old 04-08-2010, 07:52 PM
nvsteve's Avatar
nvsteve
nvsteve is online now
Autolite 4164
NGK DCPR7E
Champion RA8Hc
I like NGK and Autolite.
Old 04-08-2010, 07:53 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,480 Likes on 3,320 Posts
Why not HD plugs?
Old 04-08-2010, 08:33 PM
watercop's Avatar
watercop
watercop is offline
Stock for me
Old 04-08-2010, 08:54 PM
ndnguyd's Avatar
ndnguyd
ndnguyd is offline
Stock HD plugs here.......
Old 04-08-2010, 08:58 PM
PhilM's Avatar
PhilM
PhilM is offline
STOCK!
not the $Platinum$ crap, just stock.
Old 04-08-2010, 09:01 PM
ashmarc's Avatar
ashmarc
ashmarc is offline
Agree with the rest here......unless you have a seriously built motor....stock plugs are best.
Old 04-08-2010, 09:17 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
HD Platinums work best in my 2000.
At 6500 miles, I got a miss on the stock plugs. I put in another set. I got the same results in about the same amount of miles. Then, I put in HD Platinums. I ran those 30k before swapping them out. I only swapped them because I had just put in new cams and a DFO and wanted to monitor my plug condition. That set of plugs now has 25k on it and are still running strong.
Old 04-08-2010, 09:57 PM
2nd Mike's Avatar
2nd Mike
2nd Mike is offline
I must have had a bad run of HD plugs!
I had 2 quit firing in one year(different cylinders) and 1 new out of the box that was weak.
After a few hours troubleshooting the ignition and everything else,I pulled a pair of used Autolites out of my Jeep 304(same plug) and it ran fine!
That was a few years ago but I've been running Autolites since then with no issues.
Old 04-08-2010, 11:09 PM
Anthony8858's Avatar
Anthony8858
Anthony8858 is offline
When I tried the HD stock plugs in my 2005 RKC, I got excessive vibration in my floorboards.
Changing to HD Gold plugs (for whatever reason), immediately smoothed out my ride.
Quick Reply: Best spark plugs?
