05 ultra horn
Old 05-25-2010, 08:02 AM
yota's Avatar
yota
yota is offline
Default 05 ultra horn
Not sure why but at times when I hit the horn it does not sound normal..Sorta muffled and sounds like a sick goose honking...Then later sounds normal...And back to the sick goose sound. Any ideas.
Old 05-25-2010, 08:06 AM
gambler's Avatar
gambler
gambler is offline
This horn works well, is loud, and costs a fraction of most other air horns, especially the MoCo's version.
http://www.harborfreight.com/bad-boy...orn-94117.html
Also, J&P Cycles sells a chrome version of this horn for about $20 more than HF.
http://www.jpcycles.com/product/360-...ll&results=100
Old 05-25-2010, 08:36 AM
Road Ranger's Avatar
Road Ranger
Road Ranger is offline
I had the same problem with the horn on my 05...took the leads off and cleaned them but still no good...went to the auto parts store and picked up a highway blaster has worked great since + it fits in the horn cover nicely.
Old 05-25-2010, 09:05 AM
Sammi's Avatar
Sammi
Sammi is offline
+1.
FIAMM Highway Blaster Low Tone.
Sammi
Old 05-27-2010, 05:57 AM
yota's Avatar
yota
yota is offline
Default But whats wrong with HD horn
Am getting the wrong answer here. Not looking for a new horn. Whats going on with what I have..Is it the horn...wires...swith...battery...out of gas...I asked for the news and got the weather here.
Old 05-27-2010, 06:05 AM
FXSTS-88's Avatar
FXSTS-88
FXSTS-88 is offline
Sounds like either a loose wire or a bad ground.
Clean up the connections and give it another try.
Don't know if it's 'adjustable' or not...might want to look at the screw/nut, if it is.
Old 05-27-2010, 06:39 AM
Road Ranger
As I said, I cleaned the connections checked all the grounds as stated above and it didn't help sometimes it worked and sometimes it sounded like a wounded duck. To me it wasn't worth dicking around with it. So spend 20 bucks and get a new one and then you don't have to be asking the question and then criticizing people who are trying to help you out.
Old 05-27-2010, 06:48 AM
shortride's Avatar
shortride
shortride is offline
It sounds like you have a bad horn with an intermittent problem. There's lot of vibration right there where the horn mounts to the engine.
Old 05-27-2010, 08:11 AM
frenchbiker's Avatar
frenchbiker
frenchbiker is offline
Originally Posted by Sammi
+1.
Sammi
+1. Two Highway Blaster hi and low tone, mounted on the tank front bolts, one on each side. Wired with a dual horn relay kit from http://easternbeaver.com/Main/Produc...html#dualhorns
Works great, sound great.
Old 05-27-2010, 08:17 AM
t059736's Avatar
t059736
t059736 is offline
Gotta to love your answer...:"Asked for news and got the weather"....beautiful!
Can't answer your specific problem, I spent hours trying to find the problem that I had with my horn that sounds identical to yours.
I ended up taking the advice of some of these writers and purchased a low tone horn from NAPA.
What's amazing to me is that we all continue to "pay" for the junk that's used on harley bikes.
Ride In Peace
Quick Reply: 05 ultra horn
