Adding the GPS mount from the 2010 Limited CVO Ultra
#151
Since there are so many comments on this thread, I thought this link might be of interest to people. It is a guide to several different types of GPS mounts. http://www.leadermotorcycle.com/gpsguide.html
#152
Zumo mount pics
Did you ever post the mount pictures??
I am adding the 2010 CVO Limited Ultra Zumo mount to my 2009 Ultra. It mounts through the dash pad and all the parts are easily ordered through any HD dealer with these part numbers;
1106 Screw
1107 Screw
7686 Locknuts (2)
92346-10 Mount (accepts garmin cradle)
92466-10 Retainer (goes inside fairing for support)
57885-10 Pad (dashpad specific to cradle mount, already has holes)
This will make for a much cleaner look and get the ugly mount arms off your handlebars.
I am taking lots of pictures to add to this and should be done with the mounting tomorrow afternoon and I will finish this thread after that.
1106 Screw
1107 Screw
7686 Locknuts (2)
#153
#154
suscribed. I will be doing this since I was just installing my Fairing Mounted w/o dash pad and wasnt paying attention and put the templet in the wrong spot therefore drilled a hole in the wrong spot . Luckly the dashpad will cover it as I just got inished installing a painted inner fairing
[UPDATE] Parts have been ordered. Lets hope I did not overlook a part or order the wrong one. I know one of the part numbers that is listed on here is a "saddlebag guard rail nut". I am thinking its a nut that is used in more than one spot so I ordered it. I figure if its not the right nut and the part number is wrong then I can get a nut from a local hardware store and its only .95 from HD.
#155
Found this lock
Found this lock set up some may like its not so big as others http://www.kradellock.com/
#156
I just did this dash pad and 665 mount about 2 weeks ago. I am very happy with the outcome. You can see my finished pics in my picture album and see it also in my signature pic.. Great way to install a gps.
#157
I picked up a Zumo 590LM and am still torn on how I want to mount it. My original thought was the dash mount - exactly the way you describe. The handlebar mount seems slightly easier, but the polished look of the dash mount looks so much better to me. After reading some reviews on that installation, however, folks complained that the default mount from HD does NOT allow the unit to be adjusted for viewing. It's evidently a rigid mount - no RAM ball option is included. I can hardly believe that! Can you either confirm or deny this? If the mount is rigid, have you experienced any issues with the viewing angle, sun glare, etc?
Thanks guys.
#158
OK - sorry to come late to the party.
Your RAM ball mount is ideal for adjustability, although I think I personally prefer the placement on the left side (to reduce obstruction of the speedo and tach). Do you have any issues with the unit vibrating excessively with the single point of attachment to the fairing?
Thanks guys.
Thanks guys.
http://www.pro-fit-intl.com/shopaccessories.htm
About half way down the page you will find an "easy swivel" and this will give you the adjustment options you need without a ball, and it is tight so it will not vibrate to the lowest position. There are also ball mount options here. This easy swivel will line up to the garmin fairing mount, and the garmin cradle. I have one, though I found it not necessary to use because the angle for viewing is perfect in my opinion. Hope this helps.
#159
If you want adjustability, simply go to this link:
#160
Great link - thanks! And yes, I was worried about the length of the RAM ball mount, too. Much prefer the compact approach, so this is perfect.
