Se 120r complete engine?
Old 08-04-2010, 08:34 AM
BadBagger08's Avatar
BadBagger08
BadBagger08 is offline
Originally Posted by timvan
am I the only one that sees 12:1 cr on this monster? ping ping ping baby on pump gas
No it's 10.5:1 There are optional 12:1 pistons and a few other upgrades Cams/Heads/TB/Intake that I'm sure don't add much more than another 10/15hp
The only component that makes this motor a little on the non-street able is the cam it's a monster .660 lift and lots of duration.
  #52
Old 08-04-2010, 10:23 AM
FIREHAWK116's Avatar
FIREHAWK116
FIREHAWK116 is offline
Do the cases come with the timkin bearing upgrade? Are the cranks welded? It would suck to still have to worry about the lower end not holding up.
  #53
Old 08-04-2010, 11:27 AM
nemick's Avatar
nemick
nemick is offline
I've got a feeling that there might be a rush on these beasts in the near future.
  #54
Old 08-04-2010, 11:31 AM
Lama's Avatar
Lama
Lama is offline
Screamin’ Eagle® pro SE 20R High-
Performance Crate Motor
This track-ready 120 cubic inch Screamin’ E agle® Crate Motor
is waiting to provide a racing enthusiast the opportunity to
go racing at an affordable price. This engine is designed for
bolt-in installation in the Original Equipment-style chassis
of your track bike. No special fabrication or engine-mount
relocation is required. The crankcase, cylinders and heads
are painted black, and feature machined aluminum highlights
and chrome covers for a stunning “show-and-go” look.
When equipped with appropriate high-flow throttle body
and injectors, an open air induction, and tuned exhaust, this
engine is capable of producing a reliable 135+ horsepower
at the rear wheel.
Hand assembled alongside Harley-Davidson’s production
Twin Cam engines at the Pilgrim Road Engine Plant in
Milwaukee, these race-use engines feature only the finest
Screamin’ Eagle components:
• 4.060" big-bore cylinders.
• 4-5/8" stroke premium forged flywheels.
• 10.5:1 high-compression nickel-plated forged pistons with
T eflon coated skirts.
• Titanium SST piston rings.
• SE-266E high-lift cams.
• Perfect Fit push rods +.030.
• SE high-performance lifters.
• CNC-ported MVA heads with automatic
compression release.
• Machined lower rocker boxes for valve
spring collar clearance.
• Factory-machined engine cases.
• Unique piston oilers for stroker clearances.
• Screamin’ Eagle inner crankcase cam needle bearings.
• Lefty high-performance crankcase output bearing.
• High-performance torque response engine compensator.
• SE Performance Spark Plugs.
Requires separate purchase of appropriate Screamin’ E agle
throttle body, high-flow injectors and a high-performance
clutch upgrade. Just add your choice of race exhaust, highflow
air cleaner, and tuning. For race application only.
19220-11 Black & Chrome. $5,495.95
Fits ’06-later Dyna® and ’07-later T ouring models.
19206-11 Black & Chrome. $5,795.95
Fits ’07-later Softail® models.
  #55
Old 08-04-2010, 12:55 PM
Biggzed's Avatar
Biggzed
Biggzed is offline
This sounds like a very interesting option they have just released. In the beginning of this thread I thought the OP was talking about the same old JIMS 120 motor that has been around for years. My bad for skimming.
I'll be doing some research. Thanks to everyone that posted links to what this thread is really discussing.
Zach
  #56
Old 08-04-2010, 01:52 PM
FIREHAWK116
at the rear wheel.
I read the parts list. Lefty bearing and premium flywheel. With HD you have to read between the lines. I do not see any mention of the timkin tapered roller conversion.
  #57
Old 08-04-2010, 02:03 PM
Lama's Avatar
Lama
Lama is offline
Most likely not Timken after all, as reading the SE parts catalog. These are the cases they use on the 120R:
Screamin’ Eagle® Pro Crankcase Set
These Screamin’ Eagle® Twin Cam crankcases are precisely
machined with the larger cylinder bores required to accept
4.060" cylinders. The Crankcase is pre-assembled with
Screamin’ Eagle Piston Oil Jets designed to accommodate
a 4-3/8" or 4-5/8" Stroker Crank Assembly, and features
factory-installed high-capacity Lefty main bearing, right side
bearing, and Screamin’ Eagle high-performance cam bearings.
24601-10A $599.95
24400001 $629.95
And this is the "lefty bearing" description from the SE catalog:
Screamin’ Eagle Lefty Bearing
When high-performance engine modifications are made,
the increased torque is transferred via the crankshaft to the
drive system, putting a significantly higher load on the bearing.
The Lefty Bearing is designed to provide increased load
capacity and enhanced durability in high-torque applications.
The bearing is installed in the left side of the crank case, and
supports the output shaft to the primary drive system.
24004-03A $39.95
Fits ’03-later Twin Cam-equipped models
  #58
Old 08-04-2010, 02:25 PM
Lama's Avatar
Lama
Lama is offline
What is confusing though is the fact that all 2010 + HD twin cam engines had the upgraded "lefty" bearing installed on both the right and the left side crankshaft bores of the cases.
Thus, specifying the "lefty" bearing on this 120R engine could refer to the Timken upgrade.
It's going to take someone building a "kit version" 120R to let us know by an actual visual check.
  #59
Old 08-04-2010, 02:34 PM
PWMORRIS's Avatar
PWMORRIS
PWMORRIS is offline
Man, this HD motor looks like a home run.
10.5 CR out of the box for pump gas, top of the line parts with a strong bottom end, top level heads, awsome HP, and a price point that is just incredible.
I have been an S&S guy for years, but geez, this thing just rocks...
  #60
Old 08-04-2010, 02:50 PM
Heatwave's Avatar
Heatwave
Heatwave is offline
Member
Received 1,077 Likes on 638 Posts
Maybe....I agree it's an outstanding powerplant but is it worth giving up your entire warranty by installing it. Probably a great idea for a bike out of warranty but I'm not sure it fully makes sense for a bike still under warranty.
There's no way HD will warranty any of the drivetrain after installing this engine and that should at least be a consideration for those bikes still under warranty.
Quick Reply: Se 120r complete engine?
