Buffeting/Updraft reduced by 75% and NO $
Old 09-29-2010, 01:48 AM
Razerman's Avatar
Razerman
Razerman is offline
Default Buffeting/Updraft reduced by 75% and NO $
2008 Ultra with lowers with adjustable vent doors-- This summer before a road trip I took a 7/16 socket- removed-one bolt, 3 spacers and one ni-lock nut-- to remove the adjustable (vent) doors from my lowers to give the eng some extra cool-It took 2 minutes per side to remove them and I gained an additional 2 1/2 inches by 11 inches of air flow through the lowers on each side. That's equal to adding a 5 inch by 11 inch opening!!
Now, I've reduced the buffeting updraft by 75% around the tank , I believe it's because the lowers are acting like a wall of high pressure air (at speed). The high pressure air pressure builds in front of the lowers, and spills over the top and up around the fuel tank and into my face. By removing the little, rattling plastic sliding (vent) doors it released the wall of pressure and it directed it onto the engine, (my jeans wave like a flag behind the lowers now, even at 45 MPH). I took a 4600mile treck thru 12 states in August, It was as hot as a boil on the devils a$$ for most of the trip, (10 days) The additional pressure/wind was channeled directly onto the engine as needed and not in my face. I opened the adjustable fairing wings for chest and arm cooling, (controllable). soon I will re-install the doors on the lowers for winter, but come next spring, off they come again...no need to remove the lowers. Next time you get a chance, check out how much more engine airflow your bike will have if you removed your vent doors, plus the added bonus of reduced updraft and buffeting.
Best to all:
R
Old 09-29-2010, 02:37 AM
cda7333's Avatar
cda7333
cda7333 is offline
Very cool. Thanks for the info. I'll have to give it a try.
Old 09-29-2010, 06:04 AM
JollyRogers's Avatar
JollyRogers
JollyRogers is offline
MY service guy @ the dealer actually suggested this vice removing the lowers. Good on you and look fwd to trying next spring.
Old 09-29-2010, 06:21 AM
Slash's Avatar
Slash
Slash is offline
I was thinking about doing this mod just because it seemed that there would still be plenty of foot & leg protection from the lowers from rain/wind yet probably worth the increased airflow to motor.I'm not convinced it'll provide a huge ( 75% ) decrease in updraft/buffeting but time will tell if I proceed.
Old 09-29-2010, 06:40 AM
shortride's Avatar
shortride
shortride is offline
I can't tell that there are any benefit by closing the rattlers in the winter anyhow. I've never notice any warmer air while riding. I may just take mine off and leave them off. Especially if it cut down the wind coming up from between the bottom of the fairing and the lowers.
Thanks for the input. This is great when someone shares information like this.
Old 09-29-2010, 06:52 AM
T K Glider's Avatar
T K Glider
T K Glider is offline
Gonna try it.Having a trike with more of rake I get lots of buffeting way more than 2 wheel touring models.Thanks for the tip.
T K
Old 09-29-2010, 09:11 AM
r8rs4lf's Avatar
r8rs4lf
r8rs4lf is offline
I have mine off and didn't notice any less buffeting and still have an updraft.
NoCoLoco
07-24-2011 06:43 AM
PDDGM
01-11-2011 04:26 AM
ncdan
08-05-2010 11:31 PM
rleggs
12-14-2008 08:06 PM
bdjhog
09-20-2006 01:49 AM
Quick Reply: Buffeting/Updraft reduced by 75% and NO $
