Wouldn't Go The Few Extra Steps
I have an '08 EGC with approx. 16000 miles on it. Last Saturday while cruising down the freeway my radio quit. It went stone cold dead. I figured that the fuse blew. I'm not any sort of a wrench when it comes to my bike. Took it to the dealer and told him what happened. They took into the shop and about 10 minutes later brought it back out. Said I had a blown fuse. DUHHH!!! Said I was good to go. Left the dealership and 5 minutes down the road my radio quit again. Immediately took it back. They took it back into the shop. About 30 minutes later they came out and told me that some wires inside the fairing had been rubbing on the fairing mount bracket and had worn the insulation off. This is what was causing the fuse to blow. My question is this - why didn't they check out why the fuse was blowing in the first place instead of just throwing a fuse in and telling me it was good to go?????
Did they charge you for replacing the fuse? Maybe they figured it would keep you coming back, job security.
Could have been just lazy, could be that who ever worked on it isn't familiar with electrical systems. Figured that since the fuse didn't blow immediately it was just a fluke occurrence.
Sounds to me like they made it right in the end. If I was the mech, I wouldn't necessarily assume the fuse blew because 2 wires were rubbing in the fairing and go searching for it, you know?
However, I would've stated that 'we replaced the fuse, but bring it back IF it blows again, as that means there's a bigger problem than just a fuse ...'.
Same here, if they actually did take the time to go through checking things out, and they charged you an hour of labor for doing it ($89 or so), and it was just a fuse, what then? Sounds like they did it right, unless of course the wires were easily visible and showed the wear without needing to take anything apart to find it.
ooorrrrr it could have been that he replaced the fuse, ran the bike and it didn't blow so he turned in the repair order and moved on to a job he could actually make some $$ on. (you know....the reason we go to work?)
Agreed.....fixed the problem, tested it, good to go. I wouldn't expect someone to start chasing wires on an intermitent grounding issue when the only indication of failure is a blown fuse. You could be there for days and never pinpoint the problem or it could be the first thing you look at. It's fixed and it cost $11, I'd say that's pretty damn good. Would you expect anything more from a car dealership?
