Repairing my SOHB primary chain tensioner
When I discovered that the primary chain tensioner was defective in my 2008 Ultra Classic, I decided to buy the Hydraulic Wedge 2 from SOHB.
Unfortunately, the Wedge 2 did not work all the time. Sometimes it made the primary chain quiet and sometimes made it sound very loose. It made me think that the aluminum wedge was sticking in it's track and not being effective. I took the chain adjuster out of the bike because I intended to install the 40 cent spring that so many talk about, however, when I took the chain adjuster apart I found some things that surprised me. First of all, I discovered deep scatches about 1/4 inch long, side by side, on the top of the leading edge of the aluminum wedge itself and then noticed that the scratches were caused by plastic nipples on the bottom track of the shoe where the wedge was suppose to slide over. These 2 nipples were just long enough that they not only scratched the aluminum wedge but they were preventing the wedge from sliding smoothly along it's track in the shoe unless I used considerable more force to push it past the plastic nipples. I sanded the nipples off the plastic shoe as well as smoothing off the aluminum wedge scratches. Now the wedge would smoothly slide along the track in the shoe without anything obstructing it. I reinstalled the new chain adjuster and since then I have travelled 200 miles and it has worked great. I am not saying that you should not buy the SOHB Primary chain adjuster because I think it works well as long as you don't get one with a flaw in the track of the shoe.
I also sent mine back for a refund. I had the same scratches the OP had on his. When I opened up the primary to remove it the chain had a lot of slack and the wedge would not slide forward to take up the slack.
Paul32730
12-15-2007 10:43 PM
billbarket
56
09-11-2007 06:28 AM
