Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Better primary chain tensioner
Old Apr 4, 2008 | 09:21 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default Better primary chain tensioner
Well spoke to the dealer and they said my chain tensioner may be bad as I am getting mechanical noise from my primary. Is there a better chain tensioner out there that I can have them install versus the factory one since they are taking it apart?
Old Apr 4, 2008 | 09:49 AM
Johneb48's Avatar
Johneb48
Default RE: Better primary chain tensioner
HB-125
Old Apr 4, 2008 | 09:59 AM
KBFXDLI's Avatar
KBFXDLI
Is that the hydraulic one? If so where did you get it?
Old Apr 4, 2008 | 03:10 PM
t150vej's Avatar
t150vej
I put in an M-6 (spring loaded) in '92 and haven't touched the primary chain since (about 70,000 miles)
Old Apr 4, 2008 | 03:51 PM
rbabos's Avatar
rbabos
ORIGINAL: KBFXDLI
First you need to varify it is the tensioner causing the problem. The HD unit is very well designed, for what it's worth.
Ron
Old Apr 4, 2008 | 04:54 PM
xxxflhrci's Avatar
xxxflhrci
I'll bet money it is the problem. It is not unusual for them to tighten the chain up way to tight. If you have to have an auto tensioner, get an aftermarket one.
Old Apr 4, 2008 | 05:01 PM
The Baron's Avatar
The Baron
Are y'all liking the M6 or HB125 better?
sgw1064
Jan 8, 2023 09:19 PM
Nathaniel King
EVO
15
Jun 11, 2016 07:53 AM
jpooch00
Dec 21, 2012 08:24 AM
DaShoveled one
Feb 8, 2008 11:18 AM
billbarket
56
Sep 11, 2007 06:28 AM
