Security System Smart Siren II install on 2011 FLHTCU
FYI on installing an H-D Security System Siren II (62328-06A) on a 2011 FLHTCU; just finished installing a siren on my new Ultra Classic and found the printed instructions to be lacking as they don't seem to address 2011 model changes. First, on my 2011 FLHTCU the siren goes under the left side cover, not the right side as indicated by the instructions. Second, there is no need to remove the electrical bracket (as indicated is the instructions) holding the fuse box since there is a spot on the bracket to snap in the siren next to the fuse box. The siren wiring harness connector is right next to where the siren mounts so it's ready to plug right into the siren. To secure the pager antenna wire a velcro strip is supplied with the siren kit. I found that the velcro strip is too wide to neatly fit on the frame tube above the electrical bracket as per the instructions so I sliced off about a third of it length-wise. Finally, I referred to my owners manual to activate the siren chirp sounds that indicate when the security system is armed or disarmed. This wasn't addressed on the instruction sheet. All told this install took about 20 minutes which includes time to test out the siren alarm.
Audible siren install
Has anyone attempted to install the HD audible chirp alarm on their Ultra Classic by themselves and if so were the instructions precise? I want one and checked with HD about installing and they want $125 for a 20 minute job. I am mechanically inclined enough but without proper instructions it could be difficult. Thanks for any help anyone can provide.
You saw this?
https://www.hdforums.com/forum/touri...ml#post8070015
Mike
You can run the antenna across the top left frame tube looping under the existing tie wraps like my dealer did mine, just make sure you run it on the inside of the frame tube.
Dealer ran it on the outside and seat rubbing against caused it to fray the insulation, grounding the antenna against the frame and giving a "fob to alarm range" of about 12 inches.
Don't let the $6 radio shack alternative get under your skin. The guys that go that direction get "exactly" what they pay for. And boy are they proud. They could have bought a cheaper motorcycle too, but they didn't. Makes you wonder.
I wanted the pager feature and that's what I have and it works perfectly. Be sure and get the re-chargeable pager. The one with replaceable batteries has a bad rep of eating batteries. My re-chargeable unit will go a full week between charges and it has an incredible range.
Doesn't do much good to have an alarm system if you are a quarter of a mile away and have no indication that your $6 alarm is going off. But hey, I know, saving money is more important.
You Got Questions, We Got Answers!
