Help needed cant find relay
Old 03-24-2011, 08:25 PM
Newhog's Avatar
Newhog
Newhog is offline
I have a 99 Ultra and there is a relay under the fairing next to the right speaker, it does go bad and it will keep your starter from engaging, it's a known issue with the 99's, I always carry a spare, there is also one under the seat on the far right side next to the frame.
Also check your hot wire going to that realy (under the fairing), mine had to be re crimped as it does get brittle with age.
One more thing, you all will think this is crazy but replace the eye's on the wire going to the starter at the main circuit breaker by the battery, the crimp end on that eye was too small a gauge and will get hot and open the circuit keeping the battery from engaging. Replace the breaker as well, you can get all of this at Harley or Napa.
Been there done that!
Old 03-24-2011, 11:48 PM
BBStacker's Avatar
BBStacker
BBStacker is offline
Your very best bet is to go buy the shop manual for your year/model. It is way better than trying to poke around blindly with a schematic even with all the advise you get here.
I know this didn't answer the question, but eventually it will.
Old 03-25-2011, 06:00 PM
randy1352's Avatar
randy1352
randy1352 is offline
Think I will opt for the manual love the bike but things seem to be diffrent from other years.Like the 99.I also have a 85 limited edition goldwing.So as you can see if I like something I tend to keep it. My 20 year old daugter says I have VINTAGE TASTE lol.Thanks to everyone for all your input.
Old 03-26-2011, 11:57 AM
elvisonsteroids's Avatar
elvisonsteroids
elvisonsteroids is offline
Originally Posted by inthechateau
Is your battery voltage low? Using a jumper to get it to crank is not great idea. When you crank and voltage drops below 8vdc the ECU shuts down and will not allow trigget to ignition control module and will not crank angle sensor. Get voltage up or a new battery and see what you got. If you are having to jump with a good battery you have a bad ground on teh neg cable someplace on the frame. Grounds are very important on EFI systems.
Is the ground attached to the frame in one specific spot? if so where would that be? is it easiest to try and chase the wire or is it buried?
Old 03-27-2011, 04:47 PM
randy1352's Avatar
randy1352
To all who replied. Got manual and evening of reading up.Found coil unpluged from harness.Book mirror and flashlight,problem solved.Come on heatwave.
toxicstang99
05-17-2013 07:35 PM
traildog
EVO
40
04-23-2013 10:03 PM
grbrown
04-09-2013 06:55 AM
ironheadred
Ironhead
05-11-2011 12:17 AM
vztch13
03-22-2010 07:38 PM
Quick Reply: Help needed cant find relay
