Accessing spare fuse wires?
Old 05-30-2011, 12:11 AM
myred55's Avatar
myred55
myred55 is offline
Default Accessing spare fuse wires?
I have an 09 Ultra and noticed at the fuse box there are a couple spare fuse locations that can be used for add on accessories. Can someone tell me how I can access the wires that connect to the spare fuse location(s)? I would like to add some accent lighting to the engine compartment and use one of the spare fuses.
Any help would be greatly appericated.
Old 05-30-2011, 12:53 AM
patsfan's Avatar
patsfan
patsfan is offline
Your manual may not be alot of help on this. Remove the battery. Remove the 2 bolts that hold the the fuse block to the frame. Cut the plastic tie straps on both front sides of the fuse block assembly. To be able to pull the the fuse block assembly away from the bike, there are some grooves on the bottom/back of the fuse block that hook into the battery tray. Dislodge those by picking up on the battery tray and pulling out on the fuse block enough to clear them. You now should be able to work the plastic back of the fuse block enough to clear the frame and slip the grooves on top/back. Once the back is off, you have access to the wiring.
Old 05-30-2011, 04:20 AM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
You might think about using the accessory plug, its already fused and switched.
Old 05-30-2011, 10:39 AM
myred55's Avatar
myred55
myred55 is offline
Thanks for the response Potato. But I used the accessory plug for my Road Zepplin seat.
98chevy350
2014-2023 Touring Models
16
12-15-2015 10:41 AM
iRider
Electrical/Lighting/Alarm
10-02-2014 09:12 AM
variablek
03-31-2009 09:02 AM
bobg1253
06-15-2007 01:30 AM
hunter93
09-26-2006 09:35 PM
Quick Reply: Accessing spare fuse wires?
