Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
So when I connect the 2 wires on the left to the (+) and then the two wires on the right to the (-) I get sparks.....so something is obviously shorting...
so wheres the maxi fuse at? i took out 2 fuses per the manual...well if I am closing the circuit and there is no resistance...wont the battery just drain out? isnt there supposed to be something to prevent it until i turn the ignition?
The maxi fuse is that big fuse on the Left side of the battery (Orange fuse, has a 40 on it), inside the box... Snapped on cover.... it has two wires going into it..
There will be always be a drain on the battery... it's called MILLIAMP DRAW... and it is a fact of life...
The fuses that you removed were prolly the ECM and Fuel pump... both are 15 amp...
Yep you got it...I pulled the ecm and the fuel pump....Also it seems I did pull the maxi socket out of the plastic battery box but didnt pull the fuse out of the socket...thank God I know better now....seriously! Thanks!
Voltage causes arcing, not current. Amperage kills, not voltage. You prolly have occasionally seen images of a telsa coil arcing several feet to someone's hand as a science demonstration or something. It's very high voltage letting it arc that far, but very low current making it safe.
