Lost Heel Shifter
Old 06-05-2011, 08:54 AM
jrspada4's Avatar
jrspada4
jrspada4 is offline
Default Lost Heel Shifter
So, I took my '10 RoadKing in for it's 5k service recently. I've put about 600 miles on it since. Yesterday while riding home on the interstate my heel shifter fell off. Of course, I didn't notice it until I got home. I only really use it to find Neutral and as a heel stop,so it's not a huge deal. Does anyone know if the service techs remove the heel shifter when they're adjusting the clutch? I'm hoping I can argue they didn't torque it properly if they did. I'd rather not have to pay to replace it if it was their mistake. I know it was on tight before. I torqued it myself and used Blue LocTite on it at the beginning of the season when I adjusted the height of the arm.
Old 06-05-2011, 08:58 AM
TWIN CAM 96's Avatar
TWIN CAM 96
TWIN CAM 96 is offline
No need to remove shifter to adjust the clutch. Only if they pull the primary case they would need to remove the shifters!
Old 06-05-2011, 09:03 AM
Paniolo's Avatar
Paniolo
Paniolo is offline
No, the do NOT remove the shifters as part of the service unless the primary cover has to come off.
Losing shifters is a very common problem. What usually happens is vibration shakes the bolt loose and everything loosens up and comes apart, or the splines in the softer of the two metals gets chewed up and strips out. I just replaced mine four days ago when the toe shifter stripped the shifter shaft. I had to flip my heel shifter around and use it to finish the ride and get home. One thing you can do is use a longer bolt, and secure the other end with lock nut to keep it from backing out.
Old 06-05-2011, 09:10 AM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
One of the first things I did was remove my shifter. Never use it and it was always in the way. Now I have a spare in case the toe shifter falls off.
Old 06-05-2011, 09:39 AM
Johansson's Avatar
Johansson
Johansson is offline
Did the same thing, took the heel shift lever off and put a chrome cap on it
Old 06-05-2011, 09:41 AM
harleyflyboy's Avatar
harleyflyboy
harleyflyboy is offline
That is the first thing I do is take off the heel shifter and move the toe shifter to the outer splines. Mucho better for me at least.
6 gun's Avatar
6 gun
6 gun is offline
Received 1,743 Likes on 980 Posts
you and me both, plus i took the shaft and had it cut short so it would not bother me ever again
Old 06-05-2011, 09:58 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
No need to remove it for service,but arnt they suppose to check fastners with the service?
Old 06-05-2011, 10:30 AM
cogener8's Avatar
cogener8
cogener8 is offline
I love mine and even more so after putting the footboard extensions on. Maybe some one on here that didnt like theirs can hook you up.
Old 06-05-2011, 10:34 AM
pretz's Avatar
pretz
pretz is offline
When I bought my 2007 SG I lost 2 heel shifters in under 2K. After the second one I went and bought an after market and used Locktite to seal the install.
Quick Reply: Lost Heel Shifter
