Screamin' EagleŽ Pushrods
18404-08 Screamin' EagleŽ Premium Tapered Quick-Install Adjustable Pushrods
These premium pushrods are tapered for enhanced clearance at the cylinder head, allowing the use of higher lift cams. The one-piece chrome moly tube adds rigidity and durability, and the threaded adjustment feature provides easy cam installation without removing the cylinder heads or rocker boxes. To simplify adjustment, the tube features six flats, with one flat marked with a large dot for tracking the adjustment. The threaded rod features 4 flats to reduce wrench swing. Each pushrod features the Screamin' EagleŽ logo and is marked for "Intake" or "Exhaust". Kit includes 4 pushrods and required pushrod tubes.
17997-99A Screamin' EagleŽ Quick-Install Pushrod Kit For Twin Cam-Equipped Models
These pushrods have been designed to allow for easier installation, adjustment, and improved durability. This unique Screamin' EagleŽ design allows for installation of camshafts in the Twin Cam without the removal of the heads or rocker boxes. This design is also a great performer, constructed of stiff chrome moly tubing and thread-rolled adjusters. Kit includes required pushrod tubes and clips for adjustment of pushrods.
I have a HD-Visa; I just exchanged 10,000 points ($1,000) for a Stage II 103ci Big Bore (27532-08). I am considering SE Pushrods. There are two listed; rather than asking which a better option is, I am just asking for some Pushrod insight? can anyone assist me?
TIA
TIA
Different views and opinions, but I will say that when I did my cam a few months back I choose option two. The reason being, I have seen only a few failures in the past couple of years with any SE adjustable and each time it was with the tapered ones. This made my decision for me, without this info I would have chosen the tapered ones because of what they describe, but I know what I have seen.
The -99A's can rub the tube tops and cause some noise. The nuts on the -08's have been suspect, but can be replaced with stronger which many do. If I had to do it over again and the -08's were available when I did my cams, I would have went with them. They are tapered so they don't rub and they are for higher lift cams.
i have the ones you looked at
the first ones u listed are the tapered one. I out those in my engine build. the only problem is the locking nuts are extremely brittle and break. after one split in half and one cracked while locking them down. i got 3/8-24 industrial nuts. which are long too. i ground the corners off for more clearance.
Just checking, the 08's seem to be the consensus, do I need shorter tubes of can I use the same ones?
http://www.harley-davidson.com/gma/g...wl_listing.jsp
