How to change the trottle grip
Old 12-06-2011, 08:31 AM
equandt's Avatar
equandt
equandt is offline
Originally Posted by mlbraptor
I thought it went under the seat...
You're in the wrong forum if you want to do that...go to the V-rod forum.
  #32
Old 12-06-2011, 08:53 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
Originally Posted by 2WheelGlider
Did you buy new heated grips? The Limited has heated grips so if you change them dont you need ones that are heated? I would like to change mine but was under the impression I would have to buy heated ones and they are just so dang expensive. Am I missing something?
I found the heated grip wire up against my TBW while changing n
my handleabars.....not sure if its setup for it anywhere im the circuit but its there so I wonder if all Touring models have a heared grip?
  #33
Old 07-24-2012, 01:18 PM
1sweetglide08's Avatar
1sweetglide08
1sweetglide08 is offline
Originally Posted by 2010 Raffel Road King
Also make sure you put a spacer in the brake handle to protect the brake switch.
Not really sure what you're talking about by putting a spacer in the brake handle to protect the brake switch.
  #34
Old 07-24-2012, 08:10 PM
papifun's Avatar
papifun
papifun is offline
how about photos of a procedure that someone does with TBW ?
  #35
Old 07-24-2012, 09:09 PM
TKDKurt's Avatar
TKDKurt
TKDKurt is offline
Originally Posted by bberck
It's much easier with throttle by wire. Nothing to it really just a gear at the end of the bars that slide into the teeth in the end of the grip.
Changed the bars and grips. Easy.
  #36
Old 07-24-2012, 09:11 PM
TKDKurt's Avatar
TKDKurt
TKDKurt is offline
Here is a good illustrated thread about changing out the bars and grips with good instruction on the throttle by wire and also showing the spacer on the brake lever. I followed them when I did my switch.
https://www.hdforums.com/forum/touri...road-king.html
  #37
Old 07-24-2012, 09:17 PM
2kids3pets's Avatar
2kids3pets
2kids3pets is offline
Timely post...swapping out grips this weekend
Cornel
10-27-2011 05:56 PM
Bugspit
12-19-2010 09:38 PM
jcanrun
05-17-2010 12:01 PM
MyClassic09
01-01-2009 10:50 PM
Dsanchez
03-03-2006 06:16 PM
Quick Reply: How to change the trottle grip
