Primary on 2002 Road King
Old 11-19-2006, 06:50 PM
swiftlube's Avatar
swiftlube
swiftlube is offline
Stage I
Default Primary on 2002 Road King
I am a new owner of a 02 Road King. I am getting ready to change the oils. Is there a drain for the primary or do you just unscrew the access plate? Once drained how much oil does the primary hold?
Thanks for the help.
Old 11-19-2006, 07:03 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Neggy ZRXOA 5248 is offline
Default RE: Primary on 2002 Road King
look for a pipe plug in the outer housing just under the derby cover Torx 27 maybe? look at 6 oclock under the derby cover
Old 11-19-2006, 07:11 PM
67xlch's Avatar
67xlch
67xlch is offline
A pipe plug below the clutch access cover to drain and 32 oz of your favorite Primary Chain Case oil IE; FORMULA + OR 20-50 Amsoil. While there, check the primary chain and clutch adjustments. A manuel helps.
Old 11-19-2006, 08:40 PM
Longtimegone's Avatar
Longtimegone
Longtimegone is offline
When you replace the plug, put tape around the threads and don't screw it in too far. You should pick up a service manual.
bladeguy
10-07-2017 10:22 AM
Slyvest
06-05-2014 11:28 PM
HDF Tech
02-26-2013 11:14 AM
00FATBOY
04-05-2009 10:20 PM
RoadKingon
Oil Archive (no new posts)
04-25-2007 10:42 AM
Quick Reply: Primary on 2002 Road King
