160/60/18 or 150 /70/18 rear?
Old 10-07-2011, 04:15 AM
Hoblick's Avatar
Hoblick
Hoblick is offline
Default 160/60/18 or 150 /70/18 rear?
i finally decided to order a matching rear wheel for the SG, i ordered an 18 x 4.25
im wondering should i go with the 150/70/18 or a 160/60/18 rear tire?
does the 150/70 add any height over the stock tire dimensions?
currently im running an avon 150/80/16 on the bike, and dont want to add any height to it.
plus i think the lower profile of the 160 will look a little nicer
suggestions anyone.. and any one have any pics of either setup 160/60 or 150/70?
also what tires are you guys running in those sizes, what fits , what doesnt? any modifications to the belt guard?
Old 10-07-2011, 06:16 AM
131tman's Avatar
131tman
131tman is offline
Pirelli Night Dragon 150/70-18 76H REINFTL
Old 10-07-2011, 09:18 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Avon give useful dimensions on their website here. Their tyres that fit Harleys are Venom, Cobra and Storm. The only tyre I can see in their range likely to fit is their 160/60ZR18, which is similar in rolling diameter to an MT.
If you are considering other brands, check out their websites.
I have a Deuce rear wheel which I plan fitting to my Glide, using a 160/70 Storm. I reckon it should fit with a squeeze!
Personally I want to use tyres with a suitable load rating for our heavy bikes. Looks like you and your preferred passenger are lightweights, but those of us not so svelte (Mrs B and I!) like the idea of a 79 over a stock 74. That 160/60 is only a 70.
Old 10-07-2011, 09:57 AM
hog95023's Avatar
hog95023
hog95023 is offline
You running the 21 on front again?
Old 10-07-2011, 12:39 PM
Biggzed's Avatar
Biggzed
Biggzed is offline
I'm running the 150/70/18 on my 4.25" rim. I've never tried the 160/60. I can tell you the Metz 150/70 fit with no issues. When I switched to the Avon Venom 150/70 it hit the belt guard. I honestly can't tell the difference in ride or handling between the Metz 880 and the Avon Venom. I get the same mileage out of either brand. I run pressure at 46 rear and 42 front. I'll go up two pounds when I'm loaded if I think about it.
Yes, I get every last mile out of a tire.
Zach
Old 10-07-2011, 12:51 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
We have had a lot of customers complain about a speed wobble with the 160/60-18 which is why we recommend the 150/70-18.
Old 10-07-2011, 12:55 PM
bagman1's Avatar
bagman1
bagman1 is offline
Now that is some valuable information, could save you a ton of headache and bucks!
Old 10-07-2011, 01:39 PM
'05Train's Avatar
'05Train
'05Train is offline
I'm running a Metz ME880 radial 160/60-18 on the Night Train. No wobble at all.
Old 10-07-2011, 02:28 PM
thenewrage's Avatar
thenewrage
thenewrage is offline
subscribing
Old 10-07-2011, 02:51 PM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
To directly address your question, the 150/70 or the 160/60 will not add any hieght since your changing from a 150/80.
Quick Reply: 160/60/18 or 150 /70/18 rear?
