Truck Lite and flash to pass garage door opener???
Old 04-25-2012, 05:41 PM
Gunslingerglide's Avatar
Gunslingerglide
Gunslingerglide is offline
Default Truck Lite and flash to pass garage door opener???
Hey all I was just curious if anyone has installed the flash to pass garage door opener with thier new Truck Lite phase 7 or any TL for that matter? I recieved my TL PH7 headlight, but havent gotten around to installing it yet. I currently have the flash to pass opener, (hit high beems twice) installed with my stock hologen setup and was wondering if it will work with the TL? I'd hate to splice into the wires and screw up a new headlight. Has anyone tried this??? Thanks
Old 04-25-2012, 05:49 PM
wlibert's Avatar
wlibert
wlibert is offline
I am not sure what the flash to pass opener does but I have the Harley garage door opener and just installed the Truck Lite Phase 7 LED headlight and passing lamps and my Harley garage door opener works fine with it. You just flick the headlight switch from low to high to low and it works.
Old 04-25-2012, 06:05 PM
Gunslingerglide
wlibert-Sounds like flash to pass is essentially the same thing as you have. Its been a couple years since I installed it, but I remember screwing/splicing into the wiring harness and just wasnt sure how it would work out with the TL. Thanks for the info.
Old 04-25-2012, 06:32 PM
ClassicBill's Avatar
ClassicBill
ClassicBill is offline
I've got the ftp with my TL led's and it works just fine.
Old 04-25-2012, 06:34 PM
mjb765's Avatar
mjb765
mjb765 is offline
I have the phase 7 and the flash to pass and it works fine.
Old 04-25-2012, 07:11 PM
Gunslingerglide
Thanks guys
Old 04-25-2012, 10:37 PM
Gunslingerglide
Light is installed and everything works great....boy is it bright!! Thanks again to all who replied
Old 04-26-2012, 09:46 AM
dougbk's Avatar
dougbk
dougbk is offline
Works fine with the HD LED and there is no reason it wouldn't work with the TL because it works off of the electrical impule in the wire not the light.
Old 04-26-2012, 10:01 AM
jharanin's Avatar
jharanin
jharanin is offline
No to hijack the thread, but are you guys happy with the TL set up I.e. brightness, quality. Can you provide a part number? I have an 07 SG I'd like to put one on. Thanks
Old 04-26-2012, 01:12 PM
jkrahn's Avatar
jkrahn
jkrahn is offline
Not sure why but my F2P is basically junk right now. When it works, it requires 3 to 6 attempts before the door opens or closes. I put one on my bike and one on my wife's car; neither works properly. Am I doing something wrong?
Quick Reply: Truck Lite and flash to pass garage door opener???
