2001 Harley Roadking Alarm Issues
The other day, I started my bike and when I turned on the switch, the turn signals started blinking like the alarm was engaged. After 30 seconds, it went off. The bike started with no issues.
I never engage the alarm and always keep the key fob in my rear crashbar bag by itself.
Does anyone know how to get it to stop blinking? It is annoying... I tried turning the alarm on and then back off. This didnt help.. Any suggestions will be appreciated..
Thanks,
J
Thanks,
J
I think it's telling you that there is a trouble code stored in the ecm.
Had a '01 EGC with the same problem. First check the battery in the alarm unit itself. Mine was located on the right side, just under the seat. Access to the battery is tough, need to pry the cover off and then tape it back down. I believe it uses a 9v battery. Sorry to say, but I eventually had to have mine replaced by the dealer. Had a new alarm system installed. Might want to consider having the unit pulled altogether if you are not using it.
