Independent Control Auxiliary Lamp Wire Harness Kit
Old 05-08-2012, 04:18 AM
dlongo8241's Avatar
dlongo8241
dlongo8241 is offline
Default Independent Control Auxiliary Lamp Wire Harness Kit
Can someone please post the pdf file for the instructions to this part for a Ultra? Do you have to pull the front fairing off for installation? please advise........
Part # 69200441
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old 05-08-2012, 05:39 AM
z71_fourwheelin's Avatar
z71_fourwheelin
z71_fourwheelin is offline
Reach under the ignition cap and pull the plug down. release plugs for each other. install harness. tuck back into fairing
Edit:... Mine was hanging down where I could do it without removing the front fairing.
Old 05-08-2012, 07:05 AM
Romingnometx's Avatar
Romingnometx
Romingnometx is offline
I put one on with my LED's and love it. Couldn't do mine from the bottom, but I've been into the fairing several times and most likely zip tied the wires tighter to keep rubbing down.
Old 05-08-2012, 08:15 AM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,364 Likes on 2,619 Posts
Part # 69200441
Here's your instructions: http://www.harley-davidson.com/en_us...ts/-j05534.pdf
Old 05-08-2012, 08:48 AM
Terrabella's Avatar
Terrabella
Terrabella is offline
Part # 69200441
I did mine with the HD part. Pretty easy to do. I had to remove my front fairing however. The only problem I had was braking apart the original connection to install the new wiring harness. I had to use pliers to brake the connection. There is a little tab holding the connections together which must be pushed down in order to release the connections. Once that was completed, its just a plug and play deal. Good luck!
Old 05-08-2012, 05:53 PM
dlongo8241's Avatar
dlongo8241
Thanks for your replies......going to give it a shot...
Old 05-08-2012, 06:07 PM
K Melancon's Avatar
K Melancon
K Melancon is offline
This is what the shop tech told me and also went into the showroom and look under one bike said nope and went to another reach in under the panel pull a wire harness and said this is it, just un plug and plug the new harness inline. Just above the right fork and top triple tree under the switch panel even with the accessory switch. Of course I get home look under mine and can't reach it. I had to pull the front outer fairing off. Takes about 15 minutes to complete instead of 1 minute.
After installing when the ignition is on or to accessory position the spots will be on. You will have to turn the spot switch off if you want them off. So dont turn your ignition switch to acc to listen to the radio without turning the spots off.
Old 05-21-2012, 09:12 PM
hutch4's Avatar
hutch4
hutch4 is offline
Has anyone put these on a 2012 ultra CVO? I've looked on mine and the cable is different since the spot light switch is also the cruise switch.
Old 05-21-2012, 09:34 PM
HDRick's Avatar
HDRick
HDRick is offline
Put one on my '09 CVO Ultra. Same switch as yours.
Old 05-21-2012, 10:01 PM
DHubbs's Avatar
DHubbs
DHubbs is offline
Subscribed
Quick Reply: Independent Control Auxiliary Lamp Wire Harness Kit
